200tdi engine compartment layout - Defender Source
Old March 7th, 2010, 06:11 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
anyone posted pix of this or can direct me to a URL? I'd like to see stock layout of stuff as well as anyones builds...
thnx
George
Old March 7th, 2010, 08:36 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
here's a few I found
ID:	25586   Click image for larger version
Old March 7th, 2010, 08:40 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I used this one when installing my 200tdi
http://smg.photobucket.com/albums/v3...0engine%20bay/
If you need anything let me know and I can snap a pic. I tried to get mine as close as possible to the factory setup.
Old March 8th, 2010, 08:08 AM
Gkase's Avatar
Gkase
George Kase
Tom and Dave,
thanks much for that...but I'm looking for a LHD configuration...just to see how others set up their power steering pump, coolant hoses and air cleaner...actually I guess a stock LHD engine layout of any kind...but thanks also for using the term engine bay...I was searching for engine compartment and wasn't coming up with anything useful...will try engine bay today...thanks again...
George
Old March 8th, 2010, 08:44 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Turbo pipes, intercooler, air cleaner, down pipe, fuel lines, fan shroud and coolant hoses will be the same RHD and LHD.
Heater hoses, heater, steering parts, throttle cable are diffrent. I am sure there are other bits as well but thought it might help some.
Check Ebay in countries that had LHD such as Italy, Germany, Spain and many more
Old March 10th, 2010, 03:53 PM
Originally Posted by Gkase View Post
Tom and Dave,
George
George- Like Dave said its all the same on a lhd truck. The difference it the power steering lines. I bought the stock 200 Tdi lhd hose from George @ RDS. Pretty sure he still list them on his site. The res for the steering mounts in front of the coolant res on the right side of the engine compartment. The Airfilter also mounts the same regardless of left or right drive.
200tdi, engine, part, tdi
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
200tdi with no engine numbers tomaco1 Defender Technical Discussions 10 August 4th, 2008 05:13 PM
200tdi retrofit, what to check/service on the engine before fitting? headdamage Defender Technical Discussions 4 March 3rd, 2008 12:51 AM
