200tdi electric fan switch - Defender Source
Old June 30th, 2010, 02:40 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I need a switch that will thread into the thermostat cover and turn the electric fan on and off. I have a bunch, one runs the fan all the time and the other seems to never turn on.(Even held a lighter near the bottom of it) they both are marked 98 celcius. Does anyone know what temperture it should come on at?
I also have one that says 91 celcius.
The 98 degree one(209F) didn't come on the other day so I'm a bit concerned. It was the first time the truck went above 210F.
Old June 30th, 2010, 07:44 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
I bet you could get some kind of thermoswitch at Autozone, or advanced auto parts (or the like). In the past, I've bought generic electric fan setups for other builds, and they always have one of those things included. Often, they will stick through the cooling fins of the radiator, so installation is generic. Though I don't know the spec of when a Tdi clutch kicks in, most vehicles with electric fans kick on somewhere in the vicinity of 190. Often, fans will have a 2 stage switch (high and low), and the faster speed will kick in at about 210. Again non-rover specific info. Good luck!
Old July 1st, 2010, 08:53 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I ordered PRC3505 which opens at 100C(212F) and closes at 94C(201F) its shown for Discovery A/C fans but am hopeful it will work with the 200tdi. Is 212F too high? I've only gotten to that temp once when I pulled off the highway when it was 90F
and I left the truck running to fix something for a few minutes. Cooled right down as soon as I started moving.
Old July 1st, 2010, 10:22 AM
Turbofan's Avatar
Turbofan
Ethan
Be sure to post how well it works. I'm going the electric fan route with my 200tdi as well. I think I'll also incorporate a manual override so I can control mine via a toggle as well.
Old July 19th, 2010, 06:35 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
My fan finally kicked on Yesterday, first time I have heard it in a year. I was sitting on the side of the road eating lunch and it kicked on,. ran for a few, saw the gauge drop, kicked off, Very excited.
The switch I wound up using was a VW switch that had a lower turn on Temp (195 F range), it was a tiny bit smaller thread size but it tightened up and doesn't leak.
I had ordered PRC3505, but when it came it was stamped with a higher temp than I was expecting 102C I think.
200tdi, electric fan, fan, switch, tdi
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
Electric fan Thermostat Placement on 200Tdi newfD90 Defender Technical Discussions 0 October 21st, 2008 02:39 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Defender fan speed switch used draaronr For Sale - Parts 0 January 1st, 2005 11:22 PM
