200Tdi Electric Fan Preferences - Defender Source
Old April 23rd, 2014, 06:55 PM
I just ordered an Ex-Fan switch and am shopping for an electric fan setup for my 200Tdi.
I have seen that the Taurus setup may over tax my stock alternator. Will my stock alternator work? What else have you guys had success with?
Thanks!
Old April 23rd, 2014, 07:11 PM
All the electric fans I've ever seen have a thermostat controlling them.
Old April 23rd, 2014, 07:12 PM
That is correct. That is what the X-Fan switch is.
Old April 23rd, 2014, 07:57 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
16" spal fan the best but next is the zirgo as I have fitted, search my build b777onr for pics
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 23rd, 2014, 08:07 PM
The Taurus fan is a great fit. You can use the low speed connector on it if you do not want as much draw. On high speed it will only come on for 10 seconds max. It will really never need the high speed.
My personal preference for control is the Dccontrol dual relay controller. http://www.dccontrol.com/relay_controllers.htm Waterproof and designed and built beyond OEM levels.
Old April 23rd, 2014, 08:28 PM
This was my install: http://www.landroveraddict.com/forum...threadID=56139 I used a Flex-a-lite controller as the Dccontrol one was not available. If I were doing it today, I would get the Dccontrol unit.
Old April 24th, 2014, 11:09 AM
Nobody else has used an electric fan in their 200Tdi?
Old April 24th, 2014, 12:05 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I have both VC and electric as I have AC. I wired up a thermostatic switch so the electric fan comes on at 205 if the AC is off (automatically comes on when the AC is on) and then the VC comes on at whatever temp it is supposed to (it was coming on at 220 climbing a huge grade with the turbo having massive boost leaks and dropping temp to 210). The switch is adjustable if need be (ie climbing off road on a hot day can have it on at what ever temp I want). I also installed an 82C thermostat so now fully loaded at 65-70 mpg i run 188-190F. Been a long road for me (as it has for most of us) but this set up is working well.
Old April 24th, 2014, 12:20 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Just spent 2 weeks in southern California with my 200tdi 110. Running the viscous fan only fresh tstat and a recored radiator. Had a higher efficiency core put in last summer. Also ran the cooling system depressurized the whole trip and had no cooling issues whats so ever. Hottest temps i saw on the vdo gauge were 195 and thats running about 1150 egts up a long grade Normally stays right at 190. Had a full length roof rack and rtt on as well for the trip.
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 24th, 2014, 04:02 PM
El Solis's Avatar
El Solis
Chris Solis
RovingRyan that sounds perfect! How did you run the system unpressurized and what are the specs on that rad? My temp is good but def climbs while I am climbing.
Old April 24th, 2014, 04:11 PM
Originally Posted by El Solis View Post
....and then the VC comes on at whatever temp it is supposed to (it was coming on at 220 climbing a huge grade with the turbo having massive boost leaks and dropping temp to 210).
Sounds to me like your VC is not locking up early enough.
There is no way mine has ever been above 90 C (195 F) with the Taurus fan and it never is on for more than 10 to 20 seconds at a time.
Old April 24th, 2014, 04:17 PM
El Solis's Avatar
El Solis
Chris Solis
Yeah when i took it in for the turbo boost leaks the shop figured that out as well and put a new viscous hub on, now i haven't heard it come on. warmest it got was 205 up a long climb. Not sure what temp the VC is supposed to come on but my electric fan is set for 205 and it works well
Old April 24th, 2014, 04:31 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Thanks!
What? Is your mechanical fan not getting the job done? Or is the fan shroud just too unsightly?
Fwiw I've got a 200tdi radiator in my Series 1 and I'm using a Spal 16" fan. Fits perfectly.
Old April 24th, 2014, 04:40 PM
The first worry was about the alternator. What alternator do you have? The fans never run enough to matter. Regardless, if you have a 45 A, it is best to at least change to the 65 A one. Besides the higher output, the voltage control is better.
Old April 24th, 2014, 05:25 PM
I had my doubts but just came back from a freeway road test at 70 MPH. I think it is fine but I may still go electric anyway.
Pretty sure its a 65 A but I need to check to be sure. The motor came out of a Disco so it is whatever was standard for that.
Old April 24th, 2014, 05:33 PM
meatblanket
Mike Simpson
My mechanical fan seems to keep my 200tdi cool enough, but then again I don't live at the fiery gates of hell like you do.
Old April 24th, 2014, 05:43 PM
El Solis's Avatar
El Solis
Chris Solis
Yeah in N CA there is a hill everywhere I drive locally and to get to Tahoe etc and it is 90-100 most summer days so anything I can do to help the old girl I'll try
Old April 24th, 2014, 05:47 PM
If it is a Disco motor, you can also add a 100 Amp unit as those were OEM and fit without problem.
Old April 24th, 2014, 06:29 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
My lower radiator hose developed a leak at the fused connection on day three of the trip so I wrapped it with some thin rubber and a clamp. After that I didnt want to push my luck so I ran the remainder of the trip with the expansion tank cap loose and wedged so it would not come off...This kept the system depressurized and I had no issues, although I had my doubts early on.
I had a local radiator shop do the recore.. Receipt doesnt really say anything useful other then HE 3 Row TQLF core
Ryan
84 110SW County LHD
07 L322 Vogue
Old June 7th, 2014, 04:20 PM
Quick update. I installed the fan today on the hottest day of the year so far. I started using Red90's write up as a guide and didn't like the way it was going to come out. I had a 300Tdi fan shroud laying around so I cut the Taurus fan out of the included shroud and riveted it into the 300Tdi shroud. It looks like a factory install.
ID:	96403   Click image for larger version
200tdi, electric fan, fan, tdi
Your preferences for synthetic oil viscosity Anschluss Defender Technical Discussions 23 January 18th, 2014 10:53 PM
Wax preferences Landyman1 Defender Technical Discussions 9 May 25th, 2013 09:17 AM
200tdi electric fan switch tomaco1 Defender Technical Discussions 4 July 19th, 2010 06:35 AM
SPAL 11" Electric Fan and X-Eng X-Fan Kit crown14 For Sale - Parts 2 February 5th, 2010 01:12 PM
Electric fan Thermostat Placement on 200Tdi newfD90 Defender Technical Discussions 0 October 21st, 2008 02:39 PM
