200tdi EGT probe location ... - Defender Source
Old May 14th, 2007, 05:39 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I am looking to put in a probe for my EGT on the 200tdi and was wandering where others have drilled to put it in. Any suggestion welcome and pics are a plus.
Thanks all
Pat
Kirk Lazarus, Tropic Thunder
Old May 14th, 2007, 12:57 PM
Assuming you mean a Defender 200TDI, the best location (IMO) is in the manifold just below the turbo flange. It requires the manifold to be out unless you have a right angle drill or similar. This will thus give the pre-turbo temperature for the combined gas flow.
An easier to install loaction is on the #1 exhaust pipe, which is where I have mine as I've been too lazy to pull the manifold.
Old May 14th, 2007, 02:26 PM
Retrofit's Avatar
Retrofit
Pat
Well ...
It look like I am going to get a taped sleeve welded on the #4 on the exhaust manifold so that I can screw my probe there. I like the idea that I can remove and replace the probe over time.
It is still not done so if anyone with other input out there, speak up !
Thanks all
Pat
Old May 15th, 2007, 12:16 AM
You can drill and tap the manifold directly. It is pretty thick.
200tdi, tdi
Defender 200tdi wastegate / boost tee location dave_lucas Defender Technical Discussions 9 November 18th, 2009 04:18 PM
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 11:31 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
