200tdi disco motor high egt with new full width intercooler - Defender Source
Old May 29th, 2016, 12:01 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
After last year running slow and having high EGTs, I broke down and purchased a full width Intercooler and new radiator. Had the injection pump bench tested and the injectors rebuilt. New timing belt.
So was all excited to see the reduction in EFTs. Nope. My disco200tdi still runs high EGTs. A lot higher compared to Roving Ryan's 200tdi. I am at a loss. I am down on power compared to Ryan's. 14lbs boost. Played with the injection pump settings. Main fuel, smoke and fuel pin adjustment. Still high. A little more power.
So...what does the pool of knowledgable people here advise?
Thank you
Anthony
Old May 29th, 2016, 12:12 AM
Valves adjusted?
Pump timing?
I don't have proof but somebody told me Roving Ryan adds Gypsy tears to his fuel.
Old May 29th, 2016, 12:27 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Originally Posted by javelinadave View Post
Valves adjusted? Pump timing? I don't have proof but somebody told me Roving Ryan adds Gypsy tears to his fuel.
Valves were adjusted recently, and we advanced pump timing a hair.
I drove Roving Ryan's. It must have something injected other than diesel.
Old May 29th, 2016, 01:32 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
So to clarify further here are the details on mine
Defender 200tdi
Newish turbo with boost turned up to 14lbs
Injectors rebuilt about 15k ago
Lots o pump tweaking
Stock Intercooler
Stock exhaust
My gypsy tears tank sprung a leak so only running on b20.
Both rigs are similar set up weight wise and both with rtt.
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 29th, 2016, 10:19 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Is Compression good? What condition is the turbo in? Sounds like you've addressed the fuel and air side of the equation.
Old May 29th, 2016, 10:23 AM
Same transfer case ratios?
Old May 29th, 2016, 10:25 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Both 1.4 ratio.
Not known on compression and assume turbo is original, was tested at shop to be at 14lbs boost.
Old May 29th, 2016, 10:33 AM
What exactly are the EGTs at sustained full throttle and how do they change with engine speed?
What is top speed? What is 0-60?
Old May 29th, 2016, 10:36 AM
I recommend taking as much out of the equation as possible.
drop boost pressure to 10 or 11psi as per factory stock first. get the turbo back into its efficient region.
Old May 29th, 2016, 10:43 AM
Lowering boost will increase EGTs.
Old May 29th, 2016, 11:28 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Both at sustained full throttle with get to 1250 on egts. (and beyond but that is where i back off) Anthony much faster then I and at a lower speed. On flat ground with no head wind holding 60ish i am typically around 750-850 on the egts. Anthony was higher at 950-1050. On Anthony's we started at a stock tuned pump with the new allisport full width intercooler. All tweaking was done to further improve power. We do need to get a boost gauge mounted in his permanently and that is the next step.
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 29th, 2016, 04:35 PM
Naplm00
Matthew
Any chance the gauge is borked?
Old May 29th, 2016, 06:50 PM
Shouldn't the FIP reduce fueling appropriately with boost? If it doesn't, doesn't that signify a problem?
Old May 29th, 2016, 07:09 PM
The boost diaphragm maxes out around the stock boost level.
Old May 29th, 2016, 07:14 PM
Right, but isn't the OP's baseline FIP tuned rich to begin with? Therefore, the "maxed out" boost diaphragm is dumping fuel. My point is to return to stock tune and therefore lean out the engine.
The OP stated that his FIP has "Lots o pump tweaking", which to me means that he is dumping fuel. Not sure why he's mystified about his EGTs running hot...
Old May 29th, 2016, 07:16 PM
All that matters is the max EGT at sustained full throttle. They will also change with engine speed. On mine, peak temps are around 3000 rpm. Find a long steep hill that takes a long time to accelerate and plant it at 1800 rpm in 5th and let it slowly rev up and note the max numbers. 1330 is the max for continuous use. It will be fine for short periods a bit higher. You probably just have too much fueling.
Part throttle temps mean nothing.
What does smoke look like?
Like I asked earlier, what is top speed and what is 0-60 mph time? Knowing those, we can have an idea of power levels.
Where is the EGT probe located?
Old May 29th, 2016, 07:20 PM
He wants more power, not less. More boost will allow more fuel with the same EGTs and more power. The 200TDI turbo won't do more than 18 psi, regardless of what you do and as long as you head gasket is fresh, you will never hurt anything. Keeping the EGTs from getting too high is the important bit, IMO, to a long life for the engine.
Old May 29th, 2016, 07:26 PM
I'm confused now. The OP stated, specifically, "My disco200tdi still runs high EGTs. A lot higher compared to Roving Ryan's 200tdi. I am at a loss."
When did he say he wants more power? Power is only weakly correlated with EGT, correct? The OP has a problem he has to solve: Unusually high EGTs. I gather that he attempted to fix the high EGTs by installing a larger intercooler, but that seems like a disjoint solution.
Old May 29th, 2016, 08:41 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I'm confused now. The OP stated, specifically, "My disco200tdi still runs high EGTs. A lot higher compared to Roving Ryan's 200tdi. I am at a loss." When did he say he wants more power? Power is only weakly correlated with EGT, correct? The OP has a problem he has to solve: Unusually high EGTs. I gather that he attempted to fix the high EGTs by installing a larger intercooler, but that seems like a disjoint solution.
OK here is where we feel there is a problem. Just as a reminder mine is the one of lots of pump tuning and tweaking. I have always had more power and lower egts in the same road conditions similar weights. (Mind you mine is a stock defender setup with nothing more then pump tuning and a few fresh components) Werraa in an attempt to figure out why and solve what ever problem there may be had the pump calibrated back to stock settings, injectors rebuilt and installed the new allisport radiator (full width) and intercooler (full width). So in theory he should be better off then me except in the power part of the equation and that is still not the case. His egts are higher then mine. Something is off with it but we are not sure what yet. We also did some pump tuning to increase power after the recalibrate (to match allisports recommendation with the new intercooler) The point here is how can I with stock parts out perform (both power and egt) then he can. That is the question I think he is trying to ask. So to further complicate this I have compared my egts to several different 300tdi 110's and the egts are about 200 degrees lower then mine (and they can pull away from me on the hills) however I attribute some of that to my tuning and am working to further improve mine.
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 29th, 2016, 09:07 PM
A larger intercooler will not get you any more power at these boost levels. The stock intercoolers do everything needed at 15 psi.
NIB front NAS insulated full width floor mat rovertrader For Sale - Parts 5 November 1st, 2016 05:43 PM
200tdi allisport full width intercooler TDI Guy For Sale - Parts 10 August 15th, 2014 04:16 PM
Allard Full-Width Aluminum Radiator chris snell For Sale - Parts 11 July 29th, 2014 12:56 PM
Cooling after full width intercooler install Hudson Defender Technical Discussions 23 October 1st, 2013 07:01 PM
No retrim kits for full width second row? o2batsea Defender Technical Discussions 0 March 5th, 2012 11:09 AM
