200tdi disco motor high egt with new full width intercooler - Page 2 - Defender Source
Old May 30th, 2016, 09:48 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Ryan are you sure your EGT gauge is accurate? And his?
Swap gauges and see if there is a difference.
Also the trucks that can pass you, what are their EGT readings under the same conditions? Are they the same set up? Weight , intercooler,ect...
Old May 30th, 2016, 10:05 AM
Anything air flow related changes the egt equation, including air filter.
A tuned engine should easily get to 1250. The point is the operator should know when to back off for a second or two or downshift to drop temps. To me the bigger issue is when a diesel cannot get to 1250. Tires size, gearing, weight of the truck, aerodynamic drag (roof rack etc) all effect the load on the engine and egts.
Old May 30th, 2016, 10:31 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Originally Posted by solarguy View Post
Ryan are you sure your EGT gauge is accurate? And his? Swap gauges and see if there is a difference. Also the trucks that can pass you, what are their EGT readings under the same conditions? Are they the same set up? Weight , intercooler,ect...
We are both using a VDO Vision series gauge and probe mounted in the collector of the manifold. No reason to believe there is a problem with either gauge. As far as the 300tdi 110s with more ability to pull hills. One is 600+ lbs heavier then me but has a much more aerodynamic rtt. The other has no rtt and was prob 500 lbs less then me. I am really not too concerned about mine although it would be great to find a way to get the egts down with no loss in power. My main point is/was to use mine as a point of reference as we tune Werraa's disco 200.
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 30th, 2016, 10:46 AM
Is the fuel filter in Anthony's truck fresh/recently replaced ? Have his injector tips been replaced (every 80k or so) ?
Old May 30th, 2016, 12:43 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Tips were just replaced and pop adjusted at local bosch injection shop. Filter is probably newer then mine (I am approaching 10k on this filter). Wouldnt hurt to freshin his filter but we are able to get black at full throttle/full boost so I would assume it is flowing enough fuel to satisfy the fip.
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 30th, 2016, 08:05 PM
carlosz's Avatar
carlosz
Carlos
have you tried running with out a muffler?, maybe clogged exhaust or partially clogged exhaust is causing back pressure leading to egt concerns...
Old May 30th, 2016, 09:44 PM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Full open 3" exhaust with no mufflers. That was a great suggestion and I didnt indicate what I had done with exhaust.
Old May 31st, 2016, 07:07 PM
carlosz's Avatar
carlosz
Carlos
fuel mixture running a little lean perhaps...
NIB front NAS insulated full width floor mat rovertrader For Sale - Parts 5 November 1st, 2016 05:43 PM
200tdi allisport full width intercooler TDI Guy For Sale - Parts 10 August 15th, 2014 04:16 PM
Allard Full-Width Aluminum Radiator chris snell For Sale - Parts 11 July 29th, 2014 12:56 PM
Cooling after full width intercooler install Hudson Defender Technical Discussions 23 October 1st, 2013 07:01 PM
No retrim kits for full width second row? o2batsea Defender Technical Discussions 0 March 5th, 2012 11:09 AM
