200tdi cyclone breather/vent line - Defender Source
Old January 5th, 2012, 04:01 PM
Naplm00
Matthew
Why is it that some engines disco or defender have the cyclone breather and a separate vent line from the valve cover and some engines/valve covers only have the cyclone breather and no bung for the other breather?
Old January 13th, 2012, 07:09 PM
Surfin' Elvis
Chuck
95 RRC 300tdi/wvo conversion
I am very curious as well. Seems like there is one crankcase vent with an engineered "oil removal" cyclone and yet the other just dumps crankcase oil right back into the breather box. WHY????
Old January 13th, 2012, 08:40 PM
additional breather hose connecting the crank case with the upper end, providing improved breathing to the lower crankcase? perhaps an attempt to cut down on leaks and improve pull through the cyclone perhaps allowing it to work better?
Old January 16th, 2012, 09:49 AM
Surfin' Elvis
Chuck
I plan to run both vents to an aftermarket baffled oil catch-can and outlet the fumes to a "road-tube" and see how things go. Crankcase ventilation was handled in a similar manner for decades. I can always re-attach the plumbing to the breather intake if I need to. No emmissions tests here, so not worried about inspections.
Old January 16th, 2012, 09:56 AM
Naplm00
Matthew
im juts planning on running the one that connects to the air intake and cyclone breather since my valve cover has no extra port in it now
200tdi, tdi
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
200tdi fuel line help tomaco1 Defender Technical Discussions 8 June 11th, 2009 02:38 AM
200tdi fuel line, hose size tomaco1 Defender Technical Discussions 5 March 12th, 2009 10:38 AM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
