200tdi cyclone breather question - Defender Source
Old March 23rd, 2014, 02:36 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I have an oil leak at the rocker cover on my 200tdi. I have renewed the rocker cover gasket with no change in the leak. It's definitely coming from the rocker cover and not from the o ring at the breather, etc. I also made sure it wasn't over torqued when installed. Compression is around 340psi per cylinder with no more than about a 7% difference between cylinders. These numbers are not as high as some 200tdi's I've seen which is usually 400+ psi. True mileage of the engine is unknown however the truck pulls great and does not smoke excessively.
I wanted to check the cyclone breather and I followed the instructions in the workshop manual. Attached is a picture of the instructions. It says to draw a vacuum from the bottom hole and to plug the two upper holes. It states that unplugging either of the two upper holes should release the diaphragm and the pressure. I made sure it was clean before testing. I can only get vacuum to build if I plug both upper holes, which seems normal. However, I can only get the pressure to release if I unplug the hole going into the rocker cover; unplugging the hole that goes to the intake changes nothing. Is this how it is supposed to operate, or is the breather potentially bad? Thanks for any help.
ID:	91689   Click image for larger version
Old March 24th, 2014, 12:06 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Anyone?
Old March 24th, 2014, 12:08 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
I have an extra if you need one
Old March 24th, 2014, 06:06 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Thanks. Any chance you could vacuum test yours to see if it operates the same as mine?
Old April 3rd, 2014, 02:07 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Well I tested a new breather and it works the same as mine. The testing instructions in the manual weren't entirely accurate. Looks like my breather isn't causing the excess crankcase pressure/rocker cover oil leak. Anyone have any other ideas to test before I assume excessive blow-by due to worn piston rings and/or cylinder bores?
200tdi, tdi
Cyclone Breather Pipe on a 200Tdi javelinadave Defender Technical Discussions 8 January 24th, 2014 12:41 PM
Cyclone breather system Jim-ME Wanted 1 October 30th, 2012 03:46 PM
200tdi cyclone breather/vent line Naplm00 Defender Technical Discussions 4 January 16th, 2012 09:56 AM
Effect of disconnected cyclone breather michael67 Defender Technical Discussions 8 December 7th, 2010 01:14 PM
300tdi Cyclone Breather hose question (where to buy) nathanwind Defender Technical Discussions 1 November 27th, 2010 01:20 PM
