200tdi compression tester - Defender Source
Old April 3rd, 2011, 10:14 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Post 200tdi compression tester
Hello, I'm looking for a diesel compression tester to work on my 200tdi. Anyone have any reccommendations? Does anyone have a preference to check it at the glow plugs vs. injectors? I haven't been able to find a glow plug "dummy". I considered buying a universal diesel compression tester gauge like a Snap-On etc. I know snap-on sells a range of adapters, but was told the 200tdi has a 90 seal angle which is specific to the 200tdi. I considered hollowing out a glow plug and attaching a schrader valve on the end. Any help would be appreciated.
Old April 4th, 2011, 05:48 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
The Ford glow plug is the same thread as the 200 and 300 tdi and I use a glow plug dummy when I test those engines. If you want I can look at the kit when I get to the shop later today and give you the name.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old April 4th, 2011, 11:44 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
As in the 7.3/6.0 powerstroke etc.? That would be helpful, thanks
Old April 5th, 2011, 10:02 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I have a Mityvac MV5535 test kit.
Chris Hinkle
Old April 5th, 2011, 03:10 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Cool, and did the glow plug adapter come with the kit or did you buy that separate?
Old April 5th, 2011, 03:27 PM
Naplm00
Matthew
Looks promising
http://www.harborfreight.com/12-piec...ter-93644.html
Old April 5th, 2011, 04:23 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Kit contains four glowplug adapters as well two injectors - sadly only one glowplug adapter fits the 200 and 300tdi - but that's all you need
You could probably get one of the cheaper kits and buy the appropriate adapter separately.
Chris Hinkle
Old October 7th, 2015, 01:02 PM
PNW110
Aaron Lennox
1985 110 200tdi
I just used the Harbor Freight kit, worked perfectly.
Old October 7th, 2015, 01:04 PM
2011 rebirth. Happy WBW...... Way back Wednesday.
200tdi, tdi
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
Oops....cage tester Buckon37s Misc. Chit-Chat 8 September 20th, 2005 10:09 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
