200tdi breather question - Defender Source
Old November 12th, 2015, 11:46 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Why do some 200tdi's have a breather going from the valve cover to the case (hose #7 in pic) and some do not?
All the defender 200's I've seen have it and some disco don't...any reason? just curious.
Name:	Screen Shot 2015-11-12 at 8.44.07 AM.png
Old November 12th, 2015, 01:59 PM
Shadygrimlin
Ron Herndon
1986 defender 90
Your crank case breather is just that. It allows for the the very small amount of combustion gases and heat expansion to escape into the atmosphere. It has a line from the breather to the crankcase so that the captured oil will return to the oil pan. On most TDI's I have seen(only about 10 or do) there is a line that runs from the breather over to the air inlet after the air filter but before the turbocharger. You must vent the case, it is not a closed system. Venting into the inlet might appear to be a closed system but it is not. I do not know if I have helped out with this explanation . I am sure that someone else step in to make it a little clearer.
Old November 12th, 2015, 02:12 PM
I think you missed the point of the question. He is asking about item 7 that connects the cam gallery to the valve cover. The cam gallery is already open to the valve gallery through the lifters and push rods. I always assumed the hose was there to prevent high gas flow up the push rods in the event of large ring blowby. I did not know some Discos don't have it.
Old November 12th, 2015, 03:28 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Just to further complicate it my defender 200 does not have it.
Ryan
84 110SW County LHD
07 L322 Vogue
Old November 12th, 2015, 03:33 PM
Looking through the parts catalog, it looks like it was deleted in later engines for both Discovery and Defender.
Old November 12th, 2015, 03:44 PM
D90user's Avatar
D90user
steve
Thats interesting and odd. I was assuming the other way around as its on every 300tdi I've seen.
Old November 12th, 2015, 04:25 PM
My 200tdi does not go to the case either.
It runs the output via tube to a tee on the intake.
Old November 12th, 2015, 04:30 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
I'm almost positive that's what mine does too. I'll have to look at it later.
200tdi, tdi
200tdi cyclone breather question Macker Defender Technical Discussions 4 April 3rd, 2014 02:07 AM
Cyclone Breather Pipe on a 200Tdi javelinadave Defender Technical Discussions 8 January 24th, 2014 12:41 PM
200tdi cyclone breather/vent line Naplm00 Defender Technical Discussions 4 January 16th, 2012 09:56 AM
300tdi Cyclone Breather hose question (where to buy) nathanwind Defender Technical Discussions 1 November 27th, 2010 01:20 PM
200tdi breather bolt? tomaco1 Defender Technical Discussions 3 October 20th, 2009 09:50 AM
