200tdi block heater vs hose heater - Defender Source
Old December 3rd, 2009, 11:39 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have the block heater for my 200tdi that I haven't installed yet,
My question is after getting the new RN catalog is:
Which is the better way to go?
the hose heater seems like a much easier install.
Old December 3rd, 2009, 12:29 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm not familier with the hose heater from RN but I the VW's often run a coolant heater. It is a little heater with a pump 110v.
I have one that I never installed in the garage if you want me to look at it.
How much is the RN unit?
Old December 3rd, 2009, 12:42 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
The 1.5 inch is $60
Old December 3rd, 2009, 01:06 PM
D90user's Avatar
D90user
steve
Seems like a great price (weird). I take it it does not circulate?
Have you seen the pan heaters?
http://www.jcwhitney.com/jcwhitney/p...&redir=k232270
Old December 3rd, 2009, 03:49 PM
You are talking of a lower rad hose heater. They would OK. The block heaters are better.
Old December 3rd, 2009, 04:49 PM
D90user's Avatar
D90user
steve
look at this
http://www.frostheater.com/
Could be adapted
Old December 3rd, 2009, 06:11 PM
Block heaters are better and a cleaner install. (keep a spare freeze plug in the truck incase the block heater starts to leak).
Old December 3rd, 2009, 08:33 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
the hose heaters are much more prone to failure (leaking) than block heaters. Doesn't matter who makes them.
Matt Browne
Old December 3rd, 2009, 08:38 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Great, because I already have the block heater.
Old December 3rd, 2009, 09:31 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
What is the proper size for the 200tdi freeze plug heater?
Old December 4th, 2009, 10:05 AM
Originally Posted by D90user
look at this
Could be adapted
I've tried one. They don't work well with the design of the Defender heating system. Natural circulation is poor and they overheat. If you really care, I'll get into more details....
Old December 4th, 2009, 10:21 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Some of the tank heaters actually have pumps in them to circulate the coolant, but those usually connect to the heater hose.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 4th, 2009, 10:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have it in my office, waiting to install. I got the part number from a post here. Can't remember it offhand.
Zerostart (aka Temro) 600W 'freeze plug heater' P/N 3100087 fits a 200TDI, I assume the 300TDI is the sam
Found it!
Old December 6th, 2009, 10:12 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Just to confuse the issue I recently looked into the same options. I ended up with a wolverine brand adhesive oil pan heater. Trucker friend of mine suggested - warming the coolant is for passengers. If your goal is to ease wear - heat the oil.
I've got mine on a timer - below zero it starts without that cold diesel knock. Instructions indicate 3 hours in -10 will bring oil to operating temps.
Easy install as well...
Henry
Old December 7th, 2009, 10:55 AM
Henry
If you live somewhere cold, you should have one of those in ADDITION to the coolant heaters as the oil gets warm. They are not high enough wattage to heat the engine by themselves.
200tdi, heater, tdi
200tdi block heater tomaco1 Defender Technical Discussions 0 March 26th, 2009 07:43 PM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Engine Block Heater for Defender 110 - tips? COSteve Defender Technical Discussions 10 December 6th, 2005 01:12 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
