200tdi Bellhousing - Defender Source
Old March 6th, 2009, 07:59 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
200tdi Bellhousing
I have the 200tdi bolted up to the aluminium adapter plate(I think thats what it called)) It doesn't seem to match up to the bolt holes on the tranny. Are there different bellhousings that attach directly to the tranny, or is that all handled with the Adapter?
I was wondering if anyone can tell from the pics if these are right?
Its a lonshot I know.
Do all LT77s have the 4 allen key bolts that hold the adapter on but don't go through the bellhousing?
ID:	18111   Click image for larger version
Old March 6th, 2009, 08:04 PM
Wait, which holes don't match? In one pic you have the flywheel housing mounted to the engine, and the other pic has the bellhousing on the trans/t-case assembly.
The bellhousing won't mate to the flywheel housing? I'm not an expert on versions and applicaitons of the LT77 trans, so I can't really solve this problem, but I thought I could help clarify the question.
Old March 6th, 2009, 08:17 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I purchased a modified flywheel housing in UK that looks like what you have (4 allen head bolts on the bottom), but it mates to a series III transmission. www.glencoyne.co.uk/200di2.htm
Old March 6th, 2009, 08:27 PM
Are you using the bell housing that came with the engine and tranny or are you using the bell housing from your petrol engine ? The bell housing and clutch cover both look correct and should mate- unless you are using the petrol bell housing in which case two of the studs and one of the locating dowels will need to be removed- when you try to line them up that will be self explanatory.
Old March 6th, 2009, 08:55 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
My engine is in the truck still, I'm using the bell housing in the pic that Danny sent me. Looking at one of the posts above, I'm thinking the allen head bolts need to be recessed, I'm not sur the ones I order are going to recess into the adapter.
That is the problem, I think that the mix up was with the 4 allen bolts. There are 3 studs that should go through to the bell housing, and the 4 allen bolts that hold the flywheel housing to the block. Do the 4 allen bolts need to be flush with the edge of the flywheel housing? Or are there cut outs on the bell housing to accomodate the bolt heads?
We thought the allen bolts went through bell/flywheel/into the block. Rookie Mistake.
I can't get to the engine to check until Monday.
Old March 7th, 2009, 08:34 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
i'm wondering if i was sent all defender parts, flywheel housing, and tranny bellhousing?
Could my flywheel housing be for a Disco200tdi?
could the tranny be from a disco?
Old March 7th, 2009, 10:26 AM
no difference between a disco and a defender 200 tdi bell housing. sounds like you are making this harder than it is.
Old March 7th, 2009, 11:28 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm sure I am!!!!!!!!!!!!!!!!!
what about the flywheel housing that attaches to the engine? Are they the same?
Doug, I just found the latch in the back of my truck, i had forgotten all about it, if your in a hurry I can do it today and try and get it in the mail.
Old March 7th, 2009, 05:21 PM
the aluminum housing that bolts to the back of the block is called the clutch cover on these engines. That is also the same part on disco & defender.
No worries- next week would be cool.
Old March 7th, 2009, 05:30 PM
You dont want to call it a flywheel housing...
Old March 7th, 2009, 07:18 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm just wondering about the 4 lower bolts (allen) and three studs.
200tdi, tdi
200tdi Build Question regarding bulkhead fitting Turbofan Defender Technical Discussions 12 October 21st, 2009 01:59 PM
LT77 & LT230 from 200TDI ajh For Sale - Parts 5 July 23rd, 2009 01:44 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
