200Tdi Battery Warning light? - Defender Source
Old July 12th, 2015, 05:19 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Rookie question here - New battery just installed and battery warning light still illuminated. Are the intelligence there to tell me that the Alternator is bad or could this be a wiring issue?
Old July 12th, 2015, 05:33 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Try and gives some engine revs. If the light goes off then it might be your idle setting (too low) mine dies that sometimes. Give it a rev and light goes off.
Old July 12th, 2015, 06:22 PM
ATX_D110's Avatar
ATX_D110
Victor
Thanks, Jeff! I know what you are saying, I had that happen quite often before changing the battery. I just returned from driving and it stayed illuminated the whole time.
Old July 12th, 2015, 09:34 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Have alternator checked out
Old July 12th, 2015, 10:15 PM
Check all wiring connections to the alternator and engine ground. If you have the type with the voltage regulator/brush pack that screws on the back, pull it off and make sure the brushes are not stuck.
Old July 13th, 2015, 11:23 AM
ATX_D110's Avatar
ATX_D110
Victor
Thanks all. Next question - What size Alternator Belt for Defender 200Tdi and I assume this can be purchased at a local auto supply store???
Old July 13th, 2015, 11:47 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
i'd just call up Rovers North and have 2x belts sent so you have a spare.
Old July 13th, 2015, 12:10 PM
Dayco 15405
10mm x 40.5"
Whack load of crossover... http://www.summitracing.com/int/part...5/applications
Old July 13th, 2015, 01:13 PM
ATX_D110's Avatar
ATX_D110
Victor
Thank you !!!
Old July 13th, 2015, 01:16 PM
While you are there...
PS belt.
Dayco 17285
13mm x 28.5"
One day I should put together a North American parts list for the 200TDI Defender.
Old July 14th, 2015, 07:22 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Red90 View Post
While you are there... PS belt. Dayco 17285 13mm x 28.5" One day I should put together a North American parts list for the 200TDI Defender.
seriously! im slightly amazed the indie vendors haven't pulled together a recommendation list. it certainly seems it would help speed up the purchasing process, idk.
