200tdi Alternator Upgrade Options? - Defender Source
Old August 17th, 2013, 01:27 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I have a LHD Defender 200tdi. I have searched the forums extensively and have not found a definitive answer to what fits.. I am in the process of wrapping up a chassis swap and still have the wings off which would make replacement simple. Alternator is currently working fine but I will be adding some electronics and would like to upgrade from the stock 45A. I think an 65-80A would be sufficient for my needs down the road. Which alternator(s) will fit in the stock location with minimal modifications? I already know the harness will need to be upgraded as well.
Ryan
Old August 17th, 2013, 01:49 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Ryan
Do you have AC?
I have a 200 amp conversion that fits the disco 200TDI engine.
RDavisinVA
Old August 17th, 2013, 10:17 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
No A/C but would like to keep my options open down the road...
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 17th, 2013, 10:51 PM
There is a 65 Amp alternator that is stock and fits directly in. That is the simplest solution. Other choices are difficult with a LHD.
Old August 18th, 2013, 12:00 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Do you have a part number? Is it a land rover alt or something else over the counter?
Ryan
84 110SW County LHD
07 L322 Vogue
Old January 15th, 2015, 06:17 PM
BlackField's Avatar
BlackField
Oscar
D110
Any part numbers or other alternator alternatives cha cha cha?
Old January 15th, 2015, 06:43 PM
Marks Landy's Avatar
Marks Landy
Mark
1985 90 CSW 200TDI
Stc234, alternator a 127 65amp 3.5 v8-200tdi
Old January 15th, 2015, 06:55 PM
the rover shop
shayne young
Same alternator as on a massey ferguson tractor.. Look on eBay.. I put one on mine and it works great.. Mine is RHD but I don't think it makes a difference.. Biiiig amps are over rated... You don't need anything more than 80 at the most...
Old January 15th, 2015, 07:01 PM
Britpart is doing a 120 A direct fit unit now. I've had one for the last year. Seems decent. Around $200.
http://www.britpart.com/parts/winchi...-upgrade-kits/
Old January 15th, 2015, 07:28 PM
bish1865
Bruce Bishop
1985 Defender 110
I bought a 90amp from a Range Rover Classic from O'Reilly's Automotive it was a straight bolt up. I drive LH drive 110 with a 19j.I believe that engine and the 200TDI share the same alternator mount. It comes with a lifetime warranty. What's nice about this alternator it has the tach. terminal
Old January 15th, 2015, 08:27 PM
The mounts are the same but you need to be careful with clearance to the intercooler pipes. It is all very tight in that area on a 200tdi.
Old January 16th, 2015, 06:25 PM
bish1865
Bruce Bishop
1985 Defender 110
Very true I forgot about the intercooler pipes on the 200 TDI. I do run an intercooler on my 19j but the routing is different. I believe I'd do some measuring of alternator diameters to see what you have to play with for room.
Old April 25th, 2016, 12:21 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
To bring this back from the depths. I did not end up replacing it until last summer but I went with the Britpart DA1195. Which is a 100a alt. The regulator failed on my previous alt and seems to be the case here again in just about 5k miles on the new unit. Don't think I am causing any issues but wondering what may be causing these failures. Anybody else running this alternator have any issues?
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 25th, 2016, 04:40 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
Batteries | Alternator Upgrade Kits | Britpart
I was concerned about fit after having read some threads on the issue but had no trouble installing the 100 amp kit (britpart DA1195). My 200TDi does have power steering, and still no issues.
DA1195 | Alternator Upgrade Kits | Batteries | Britpart
1989ish 110 300tdi (Bella)
1988 LR90 ST 200tdi (Shorty)
1991 D130 200TDi (TBN)
Old April 25th, 2016, 08:57 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I made this setup to install an AC compressor and a 200 Amp alternator on a 200TDI disco engine.
RDavisinVA
Old April 25th, 2016, 09:38 AM
No problems here. Maybe there is something causing it on your truck or it is just a weird coincidence. If the warranty replacement fails again, I would start to believe it is the truck.
Old April 25th, 2016, 09:56 AM
Naplm00
Matthew
Check my thread history, I have a massive and cheap direct fit alt in my 200tdi
Old April 25th, 2016, 10:04 AM
In a LHD, Defender 200TDI?
Old April 25th, 2016, 11:14 AM
Naplm00
Matthew
Yea I'll find it. Fits in the stock location on defender engines.
Edit: not as massive as I remember but 75amps is better than 65 I guess lol.
http://www.defendersource.com/forum/...tml#post317510
It's a Massey Ferguson mf-4225 alternator aka 12088n alternator.
Even uses the stock wiring plugs
Old April 25th, 2016, 11:23 AM
That is the normal stock 65 A alternator. Yes, they are fairly common and easy to source cheap. They are calling it 75 A, bit it is the exact same alternator referred to as 65 A that is a stock unit.
200tdi, alternator, tdi
Alternator Replacement Options for Disco 200tdi isleofbones Defender Technical Discussions 7 February 23rd, 2013 03:27 PM
Options for re-wiring a 200tdi alastair Defender Technical Discussions 23 May 25th, 2010 01:07 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
