200tdi Alternator - Defender Source
Old August 27th, 2012, 07:30 AM
bossman429's Avatar
bossman429
Adrian
1988 90
200tdi Alternator
Anyone know best place to get one? Is there a NAPA part number or something that would fit?
The housing on mine where the bottom right bolt goes in sheers in half, so its just being held in place with the 2 bolts. Its Al so welding it for me isn't an option.
Old August 27th, 2012, 07:39 AM
Naplm00
Matthew
http://www.defendersource.com/forum/...0&postcount=15
------ Follow up post added August 27th, 2012 07:41 AM ------
I bought the eBay one and swapped the pulley fir the lr one. Works great, and at 77 bucks NEW with no core it's a smoking deal
Edit: THIS IS A DEFENDER 200TDI ALT THAT I LISTED
Old August 27th, 2012, 08:07 AM
bossman429's Avatar
bossman429
Adrian
1988 90
sweet, yea mines a defender engine.
Just to be clear, you post says you bought the one from discount alternator but you said you bought it from EBAY.
Either way its the same one right?
Wait - how many bolts is it held on with?
I only see two bolt holes in the pics, but the one on my truck now had 3 (the casting broke on the third)
Old August 27th, 2012, 08:35 AM
the rover shop
shayne young
I bought the 70 amp alternator for a Massey ferguson tractor, it's a direct fit plug and all and cost me about $70 no core.. There's a thread for it somewhere..
Old August 27th, 2012, 08:37 AM
the rover shop
shayne young
Mines a defender 200tdi if that's what your looking for... And found it cheap on eBay..I think it might have also been called discount alternator and/starter..
Old August 27th, 2012, 08:58 AM
Naplm00
Matthew
Sorry yea I got confused. Same thing anyway. The Massey Ferguson tractor thread is mine. All th same part number anyway.
I'll check the mounting holes and snap a pic
Old August 27th, 2012, 09:07 AM
Naplm00
Matthew
Installed
Old August 27th, 2012, 09:27 AM
the rover shop
shayne young
Yep.. Worked an absolute treat for me and still is.. Gonna take it around the world..
Old August 27th, 2012, 10:23 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok- guess its only two holes, the other is actually the bracket. Was hard to tell yesterday, covered in mud and on my back under the truck
Old August 27th, 2012, 04:28 PM
I also bought that alternator. It came with the 2-belt pulley, which I then replaced with the original alternator's pulley. You must use washers to space the pulley properly as the ebay alternator pulley centerlines are not in line with the original 200tdi pulley.
It works perfectly though...good as new, and better than old. Tach signal through the w pin
Old August 30th, 2012, 03:32 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Got the alternator in today. Fit like a glove. I didn't need to space anything out. The pulley sat right in line when I swapped it over. Here's a pic of the failure. Turns out the rear bolt wasn't in and I guess that put a lot of stress in the front one which being aluminum sheared right off. All three bolts are in now. Should be good to go!
Old August 30th, 2012, 06:31 PM
looking good.
200tdi, alternator, tdi
Disco 200Tdi Alternator P/N? newfD90 Defender Technical Discussions 8 January 29th, 2012 07:29 PM
Alternator Upgrade - 200TDI ajh Defender Technical Discussions 21 December 20th, 2010 04:08 AM
Alternator wiring question 2.5 NAD to 200tdi dave_lucas Defender Technical Discussions 6 December 3rd, 2009 12:01 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
