200tdi Air conditioning inquiry - Defender Source
Old August 11th, 2016, 02:24 PM
dylanh19
Ben
1986 Defender 110
Hi guys, just wondering if anyone can help tell me what I have and if they've seen this system/setup before. It was a dual A/C system that I pulled from my 1986 110. The front core/blower sat where the front heater should go and the rear core/blower sat behind the rear bench, on the wheel well. I THINK there is a condensor and fan unit, two cores and two blowers, a compressor, and I think an evaporator, and most of the hoses. There is also a vent system that ran from the rear unit up and over the rear bench seats along the roof liner. It wasn't working at the time, and likely needed re-gassing, and perhaps a tune up, but I don't know for certain.
I have no need for the system anymore, but just wanted to see if anyone can give me any more information on it. The vehicle came from Hong Kong about 10 years ago, and lived in Vancouver for 10 years. I can't see any Land Rover parts markings on any of it, but the system all fit in as snug as a bug, with all mounting brackets appearing to be original and unmodified. The compressor is 'Sanden Corporation Heavy Duty.í
If anyone can tell me anything about the system, particularly what it might be worth? Iím looking to sell it as I do not plan to put it back in my truck.
ID:	155456   Click image for larger version
ID:	155458   Click image for larger version
ID:	155460   Click image for larger version
ID:	155462   Click image for larger version
ID:	155464   Click image for larger version
Old August 11th, 2016, 04:33 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
That is not factory so aftermarket components that someone fabbed and pieced together.
Where did the compressor mount (my guess is RH side of the engine if you were sitting in the vehicle facing forward).
So there are 2 separate evaporators?
I wish you had taken pictures of it before it was removed.
Can you take pictures of the hoses?
According the my research a split unit has a T-fitting to split the lines with a single compressor/condenser.
There has to be a filter to prevent all the oil from being trapped in the rear evaporator.
Without a filter, the oil will accumulate in the rear and the compressor will burn up.
Am looking in putting a rear unit in our 1983, but researching which unit to use.
RDavisinVA
Old August 11th, 2016, 07:52 PM
Yeah as Robert says it's not factory. Maybe from some local junkyard there in China.
As to value, it has some due to it being fitted already. Since it's not factory I would guess at maybe a couple hundred bucks.
Old August 11th, 2016, 09:46 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I am thinking that grey home made duct work and evaporator box was fitted on the right side of the wheel well with the cross duct along the back seat that blew the air into the back of the vehicle.
If so, since the seat folds forward for cargo and if the space is needed that duct work would either prevent the seat from going forward or it would be left in place and block the cargo area.
Either way, it would be a nuisance.
RDavisinVA
Old August 12th, 2016, 12:25 PM
GRNWOLF's Avatar
GRNWOLF
1985 Defender ex MOD OM617
I'm looking for an aftermarket AC solution for my 85 exMOD. I live in Phoenix AZ so it's stupid hot here so AC is almost a constitutional right.
Please put me down as first to contact when you figure out a price.
Thanks!
GRNWOLF
1985 Defender 110 ex MOD Wolf Tithonus; OM617
Phoenix, AZ
Old August 12th, 2016, 01:31 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Thanks!
There is a thread here on a group buy for the Diavia under dash AC setups like the NAS vehicles had. Available in LHD or RHD.
RDavisinVA
200tdi, tdi
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
Air Conditioning azdefender Wanted 2 March 8th, 2004 01:41 AM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
