+2 Shocks on 110??? - Defender Source
Old September 17th, 2010, 04:14 PM
ZachJackson
Zach Jackson
1985 Land Rover 110
+2 Shocks on 110???
Hello,
I'm new to the forum, but not to Rovers. I have a 1985 110 with some worn out shocks on it. I'm gearing up for the MAR rally and want to be in good shape for it so i thought i should probably get these shocks replaced. I'm really looking for maximum absorbtion and some extra ground clearence (2 to 3 inches). I would really appricieate some feedback on my situation. Thanks for reading.
Old September 17th, 2010, 04:30 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Congrats and welcome. If you're looking for a lift, you'll need more than just shocks. Take a look at OME, RT, genuine HD.
Old September 17th, 2010, 10:30 PM
ZachJackson
Zach Jackson
1985 Land Rover 110
Thanks for the input
i was looking at some pro-comp +2 shocks that said they could give a 2 inch lift off the ground? I know that 110s are not nessecarily trail rigs but i would just like some extra ground clearence.
Old September 17th, 2010, 10:56 PM
discotdi
Todd Miller
Land Rover
also check out Camel 4x4. they sell Ironman suspension from australia. i noticed they are around $150-$200 less than OME etc. I checked some blogs from Sa and OZ and people had good things to say. might be worth a call.
Old September 18th, 2010, 06:54 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
And 110's are GREAT trail rigs! look at the camel trophy's of the 90's and late 80's
Old September 18th, 2010, 10:58 AM
ZachJackson
Zach Jackson
1985 Land Rover 110
Thanks for the help
Im probably going to go with some PRO COMP +2s and put some bigger tires under it.
Old September 18th, 2010, 01:38 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Originally Posted by ZachJackson View Post
Thanks for the help
I don't think you get it: shocks don't allow you to go with larger tires...springs do. Pro Comp wouldn't be my choice, but that's your decision. Do yourself a favor and call RoverTym, Expedition Exchange, or any other basic Rover outfitter (RoverTym is in your neck of the woods), and they'll hook you up right.
For a 110, you have the rear Salisbury, probably drums, and you can easily drop in Dana 60 stuff in it. So if you want to go with 35-37s (good tire size for a 110), you'd want to look at AT LEAST upgrading the rear end, if not the front end as well if you want to go for some HC offroad.
Good luck, and post pics!
Cheers,
Nadim
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old September 18th, 2010, 02:08 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
To gain 2" of ground clearance you would need 4" taller tires. Going from 33's to 37's.
I think you are only kind of correct.
Adding 2" lift springs will raise everything from the frame up 2"
Body, trans, motor and everything above frame = 2" higher
Adding 4" taller tires will raise everything
4" taller tires will gain you 2" under the axles and everything else
Adding 2" lift springs and 4" tires taller will have the following result
Axles will have 2 more inches of clearance under them
Everything from the frame up will have 4 more inches of clearance
Old September 19th, 2010, 01:21 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
You forgot portals....
D2 shocks on a 110? RiftRover Defender Technical Discussions 0 October 16th, 2009 09:17 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Bilstein Heavy Duty Shocks - D90 or 110 CDeWan For Sale - Parts 4 February 15th, 2008 12:38 PM
