2" Safari Gard Lift Springs rate, Opinions? - Defender Source
Old June 16th, 2015, 01:57 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I have a set of Safari Gard 2" lift progressive coil springs, that I am putting on a 88 D90 Tdi. Two different spring rates, 200 lbs and 250 lbs. They were on a RRC and the 200 were up front and 250 rear. I will be running a winch, winch bumper, skid up front along with the weight on a 200tdi. Out back I will have a spare 265/75, highlift, and a fuel can on a tire carrier.
Looking for opinions. Should I stick with 200 lbs front and 250 rear. I have seen where some run HD springs front and MD rear with these mods, if this is the case maybe I should go 250 front and 200 rear
~ Semper Fidelis ~
Old June 16th, 2015, 03:03 PM
Ill trade you mine OME HD/MD setup
Old June 16th, 2015, 03:10 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
These are going in for now, looks like I will stick with 200 front and 250 rear based on some rate comparisons. If I can't get them to work for me I will entertain a trade.
~ Semper Fidelis ~
Old June 16th, 2015, 03:48 PM
youll be fine, they are sweet springs.
Puma 90 springs rate V8County Defender Technical Discussions 2 January 28th, 2015 07:57 AM
Safari Gard Brush Gard/Bumper iu7576 Defender Technical Discussions 1 January 12th, 2011 08:55 AM
"lift kit" opinions/advice hlamar Defender Technical Discussions 20 June 11th, 2010 11:44 AM
Safari Gard "CT" D110 in Northern California oldscratchggf Misc. Chit-Chat 8 August 20th, 2007 10:39 PM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
