2 Inch Extended Bilsteins - Defender Source
Old June 15th, 2010, 03:09 PM
CDeWan
Clay DeWan
5.3L beastie
Do anybody know if Bilstein makes a 2 inch extended shock that fits the stock defender mounts? and if so part number?
Old June 15th, 2010, 03:23 PM
I do not think so.
Old June 15th, 2010, 03:25 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
No, they don't, but you can lower the shock mount to get you another two inches of droop travel. Unless you shorten your current factory bump stop, this seems to be a workable solution, with many companies offering kits to do this in the past..
~Scott T.
'95 D-90 ST - AA Yellow
Old June 15th, 2010, 04:39 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Sort of, but they don't fit the stock mounts.
Custom made needed...Rovertracks or Rovertym...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
bilstein
extended brake lines jimmy salmon Defender Technical Discussions 12 February 27th, 2006 11:07 AM
19 inch Chrome Range Rover Wheels rvrnut110 For Sale - Parts 1 November 8th, 2005 09:14 PM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
Rovertym 1 inch spacer James For Sale - Parts 0 March 30th, 2005 06:30 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
