2.8 vs 300TDI Injectors - Defender Source
Old May 20th, 2015, 07:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Friends in Germany have located a cache of the 2.8 Diesel Injectors which are identical in appearance to the 300TDI Injectors.
These are the same price as the 300TDI injectors: $289.99 a set.
In the Mercedes world, it is considered an upgrade by some to install injectors from a higher displacement engine.
I would think the IP determines the pressure and spray duration while the Injector itself determines the spray pattern and pop-off pressure.
Knowing this I am wondering if there is any demand for these injectors in USA and/or would there be any benefit to installing the 2.8 injectors in the 300TDI.
The injector holders are identical, but the nozzles are different part numbers.
Thoughts...
RDavisinVA
Old May 20th, 2015, 07:06 PM
My 2.8 injectors are out right now with a bosch shop for a clean and test. Just heard they passed. Picking them up tomorrow. If you need pics, numbers or any technical info, let me know before they go back in tomorrow night.
They use the same copper washers (base and spill) as the 300 tdi as well, btw.
Rob, Steve at Safari has quite a bit of 2.8 biz and he's stockpiling spares. You may want to collaborate with him as well.
Mark Kellgren
KM4BOR
Old May 20th, 2015, 07:12 PM
Larger nozzles let you have a shorter injection time, which allows more power. It also lets you increase the injection amount without increasing the injection time. Overall it allows more power than with the smaller nozzles.
Old May 20th, 2015, 07:16 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I should call Steve, but know his plate is full right now with acquiring RDS.
Ask your folks at Bosch how much a new set costs and PM the answer if they provide it.
Also could you please verify that the pop-off for the 2.8 injector (0 432 193 532) is 201 bar while the 300 TDI (0 432 193 835) is 200 bar.
Thanks Mark
John, you're a wealth of knowledge.
After reading your post, I think the 2.8 injector is worth trying in a 300TDI because it may yield better performance.
RDavisinVA
Old May 20th, 2015, 07:23 PM
John. you're a wealth of knowledge.
I think what you are saying is the 2.8 injector is worth trying in a 300TDI because it may yield better performance.
Possibly. It would be nice to know the specs. In the VW diesel scene, there are dozen different nozzles you can swap on depending on your setup. These are all the same type of injectors. I did one day try to look into performance nozzles for the LR TDIs as they appear the same physical size as the VW nozzles.
http://www.kermatdi.com/-vw-nozzles-and-injectors/
Old May 20th, 2015, 07:34 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Fuel System & Camshafts - Nozzles - KermaTDI
Yes have seen chatter about this on some of the WV forums.
We just got our daughter's Jetta driving after an engine rebuild.
Would also think that anyone who upgraded to the 2.8 Turbo on the 300TDI would benefit from the 2.8 injectors as well.
RDavisinVA
Old May 20th, 2015, 08:46 PM
I've spoken with him almost every day this week since Saturday. He's available. He just ordered a bunch of stuff from M&D.
As for cost, I think a new complete injector is like $450ish. My Bosch shop can get new nozzles for about $115.
Mark Kellgren
KM4BOR
Old May 20th, 2015, 10:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I can get 4 new ones out of Germany for $289.99.
No shipping as they are hand carried by friends who travel in and out.
RDavisinVA
Old May 20th, 2015, 10:25 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
As a cost comparison, SafariHP is charging me $970 for 4 new genuine 300 injectors.
Semper Fi!
Old May 21st, 2015, 11:39 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
This would be a nice upgrade if they fit. I am looking for recon or new injectors, so if they fit the 300 I would be in for a set
Some good info: http://forums.lr4x4.com/index.php?showtopic=85172
http://gershon.ucoz.com/BOSCH/DIESEL...DISM-K0001.pdf
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 21st, 2015, 11:42 AM
Some good info: Injectors for a 2.8TGV - Defender Forum - LR4x4 - The Land Rover Forum
there is no physical difference between 2.8 and 300 injectors. it's just the nozzle settings.
Mark Kellgren
KM4BOR
Old May 21st, 2015, 11:52 AM
ini88's Avatar
ini88
Daniel Marcello
I looked up the part number and looks like they are all 200bar opening pressure, though there is one made by MAXION that doesn't have a opening pressure to it.
KBAL 90 P 37 0 432 193 631 MAXION
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 21st, 2015, 12:04 PM
Per my bosch shop, opening is 201 bar.
Mark Kellgren
KM4BOR
Old May 28th, 2015, 08:10 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Maxion was like a detuned 300Tdi that MWM made for the South American market and fitted to other (non Land Rover) vehicles there.
Santiago from Argentina (I think he's on here, he's on the AULRO forum sometimes) said it didn't have a very good reputation.
------ Follow up post added May 28th, 2015 10:13 PM ------
Which means you can run less advance and lower combustion pressures for the same power.
Having just freshly rebuilt a 300Tdi due to having a cracked piston from too high combustion pressures (I'm guessing) from running near maximum fueling and more advance, the 2.8 injector could be a good thing.
I just bought new 300Tdi injectors from Turners, 2.8 ones from M&D were too exxy for me at the time.
300tdi, tdi
FS 300TDI Injectors set of 4 rdavisinva For Sale - Parts 56 February 5th, 2016 10:15 AM
200/300tdi genuine parts (injectors, headbolts, decarb gasket set, etc) nathanwind For Sale - Parts 15 April 2nd, 2015 06:32 PM
300TDI new injectors - smoking like mad jaherring Defender Technical Discussions 4 May 2nd, 2011 11:58 AM
FS Rover V8 injectors ECR For Sale - Parts 0 March 11th, 2008 12:28 PM
fuel injectors not working matt Defender Technical Discussions 1 May 24th, 2007 06:28 PM
