2.8 TGV Turbo Diesel common parts listing - Defender Source
Old June 18th, 2010, 10:28 PM
Post 2.8 TGV Turbo Diesel common parts listing
Finally got a thread going on the 2.8 Yahoo user group, and posting here for posterity. Many parts are shared with 300 TDI's, and some are unique to that engine. There is no other listing on the net anywhere that I can find listing common parts, so here it goes. Hopefully some of you can continue to add to this listing as you research, pull parts or hear from others. The goal is the broadest collection of equivalent parts sourced here in N. America for this engine.
Serpentine belt: 300 TDI 7 groove (LR: ERR5911, NAPA NBH25070640HD or NBH
25070644)
Thermostat: 300 TDI (LR ERR3291)
Radiator hose (for Defenders) 300 TDI
Water Pump: 300 TDI
Viscous Unit: 300 TDI (LR ERR2266)
Injection pump: NOT 300 TDI - Bosch VP14
Lift Pump: NOT 300 TDI (need equivalent part No)
Alternator: NOT 300 TDI - Bosch 85A (need equivalent part No)
Alternator regulator: Not 300 TDI (used in many common applications. This is the spare to carry, not a whole alternator) (part no on part: VRB196 G65884) Thanks Pendy (you the man)
Starter: 300 TDI (LR PRC5109N , equivalent: Prestolite M93R 35259400)
Cambelt and fitting kit 300 TDI (need LR part no)
rockers and pushrods, 300tdi (need LR part no)
front crankshaft - 300 TDI (need LR part no)
Timing case seals - 300 TDI (need LR part no)
Who's got more to add? Let's keep it going. Downside is we'll end up with Toyota people lurking our forum. You can blame me.
Old December 1st, 2010, 09:43 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I don't have more to add yet. What about oil pump? Mine is taking a dump. I believe it to be different after talking to Matty.
Old December 1st, 2010, 12:01 PM
Best4x4's Avatar
Best4x4
Kelly Graham
P38
25070644) Dayco 5070630...Gates K070628
Radiator hose (for Defenders) 300 TDI PCH119060
Water Pump: 300 TDI PEB500090
Injection pump: NOT 300 TDI - Bosch VP14 300 TDI is ERR4419
Cambelt and fitting kit 300 TDI (need LR part no)Cambelt kit STC 4096L
rockers and pushrods, 300tdi (need LR part no)rockers LH ERR3342 RN ERR3343 Pushrods 546799
front crankshaft - 300 TDI (need LR part no) Late ERR4575 ...Early ERR4576
Timing case seals - 300 TDI (need LR part no)Cam seal ERR3356
Valve Cover 300-- ERR2409
I keep a list of part numbers ...very handy.
Old December 1st, 2010, 02:15 PM
Michael
Michael
Discovery 1998
Never tried it, but i head the fuel lift pump from a 300 tdi can be subsituted for the HS2.8. I know for a fact that the levers of the two are different. Are the cams that run these pumps the same and do they have the same "offset"???
------ Follow up post added December 1st, 2010 02:16 PM ------
thanx for putting together the list.
Old December 1st, 2010, 07:49 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
good list, thanks.
also oil filter for 300TDI -> AEU2147L (paddock and britpart), plf862 (proline), P1145A (Fram - also for '84 diesel VW rabbit)
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old December 1st, 2010, 10:38 PM
Originally Posted by hillstrubl View Post
good list, thanks.
Same filter the 3.9,4.0, 4.2 v8's use
Old December 1st, 2010, 11:54 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Oil filter
Mr Pendleton recommended Wix 51515 for the 2.8TGV. Worked for me so far (60k miles)
-Bryan
Old September 11th, 2011, 05:16 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Serpentine Belt
I don't know if anyone else has had this problem. I ordered a serpentine belt from
George at RDS. He didn't have a specific listing for the 2.8l but we both agreed the belt for
the later model 300Tdi was the one to go with. That belt is a 7PK1580. I didn't pull the old
belt until I got the new one. The belt (original) off the engine is a 7PK1629, which is 1629mm
long. The 7PK1580 was way too short. I called George again and the only other belt he has
for the 300Tdi was a 7PK1592 (I think). Also too short. Went to NAPA website and found the belt
with their part number ATM 7PK1629. They had to order from the warehouse but that only
took a day. Don't let them substitute a NAPA brand belt that "is a direct replacement" for the ATM
belt....cause it's not. It was about 20mm too long. Not sure other 2.8TGV engines are the same
but the ATM 7PK1629 was perfect for mine.
BTW....I don't have A/C.
Old September 12th, 2011, 12:36 AM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
looking for a motor I have an ISUZU 2.8 4JBT. Great motor but to rebuild what or where could I get the parts?
Old September 12th, 2011, 08:00 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Hello Jaime-
I don't know anything about that motor but I do have an interest
in all things diesel. Found this:
http://www.isuzutruckparts.com/?gcli...FZQW2godMTsojw
They may be able to help or at least point you in the right direction.
-Bryan
Old September 26th, 2011, 06:54 PM
I can confirm ATM 7PK1629 is the correct part no from NAPA for the 2.8 main serpentine. Fitted mine today. Thanks Rat! Now my belt squeal is gone.
I have A/C. A/C is a separate shorter belt. Now I need to match that one and post the NAPA part no.
Old April 3rd, 2012, 07:12 PM
I shared the 2.8 manual with a guy from Canada today, and in return, he shared this 2.8 parts supplier in the US!!!!! I can't believe it. This is like the holy-freakin-grail.
In English and with US pricing. Supplier is based in Miami.http://www.guerrainternational.com/e...an_ranger.html
Old October 31st, 2012, 07:57 AM
Martyn at M&D confirmed for me today that the 300 TDI pump fits on the 2.8. The only difference in the 2.8 vs 300 pump is the impeller. the 2.8 is plastic vs metal. Getting ready to replace mine as part of my 70k service along with timing chain.
------ Follow up post added October 31st, 2012 08:03 AM ------
Mark Kellgren
KM4BOR
Old January 10th, 2013, 11:32 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Does anyone know if there is an equivalent starter solenoid? I tried STC1245, but it won't work. Here is the existing.
ID:	64326   Click image for larger version
Old January 11th, 2013, 12:05 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Isn't that a Prestolite number in the second pic?
1970 SIIA 88, Sold
Old January 11th, 2013, 05:12 AM
#gmrvrswins
http://www.findpart.org/part/pre-35641020
Old January 11th, 2013, 08:00 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks, seems so! Will track one down.
Old February 18th, 2013, 10:07 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
So just to follow-up. Seems Prestolite changed the configuration of the solenoid. No longer uses a spade terminal (ring instead for the ignition) and the battery lug is significantly larger which means a bit of fiddling to replace one.
Details:
12 volt M12-1.75 BATTERY TERMINAL, M8-1.25 MOTOR TERMINAL, M5-0.8 SWITCH TERMINAL
Old February 18th, 2013, 11:25 AM
Good to know. when I looked up that part no, it was listed as common to Chevy, Mercedes and Fords. I also pics of one that still had same size battery rings and a blade trigger, so perhaps it varies.
My understanding is that the 300 TDI starter complete fits right in though if there's a desire to stick with LR part numbers. anybody understand differently?
Mark Kellgren
KM4BOR
Old February 18th, 2013, 11:33 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
To the guy with the Isuzu motor, those motors were sold in the US in the box trucks and stationary machinery, I would call an Isuzu dealer if you need parts for it, I know of a few if you need to find one.
diesel, part, parts
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
Is there a list of common parts from D1 to Defender? btate Defender Technical Discussions 1 February 16th, 2009 10:49 AM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
Diesel exhaust parts JimC Defender Technical Discussions 0 November 3rd, 2004 09:01 AM
