2.8 TGV Turbo Diesel common parts listing - Page 3 - Defender Source
Old March 1st, 2015, 05:55 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
The 2.8 pump will prime the system by turning the engine over, but some people will advise against that since you're running the IP, which uses the diesel as a lubricant, dry until fuel reaches it. If you're going this route, it's best to fill the fuel filter with diesel before installing it to minimize the time required to prime the system.
With that said, Racor makes a filter housing (model 445R) with an integrated prime bulb that is freaking awesome, and I suggest using that over the Bosch unit that is standard on the 300's. On a completely dry system it takes 3-4 pumps for a strong prime, and you don't have to worry about potential damage to the IP. The Racor also doubles as a sedimenter which is very nice. You also have an option for finer filtration elements with the Racor. On my last 2.8 build I ran two filters; one 445R with a 30 micron element, and one with a 2 micron element. The housing also has an optional heater for exceptionally cold climates like your truck may see.
Just something to consider.
-Ash
Geared Restoration Co.
352-572-3236
Old March 1st, 2015, 06:08 PM
What Ash said. That's what I have- a 30 micron prefilter and a 2 micron heated primary. I intend to replace my rear Racor element with Rob's sedimenter at some point, and put in the back electric pump that can be used for priming as well.
Mark Kellgren
KM4BOR
Old May 11th, 2016, 04:17 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Anyone confirm the oil pan gasket is the same as the 300?
Old May 11th, 2016, 04:27 PM
2.8 doesnt have a gasket. rtv only.
Mark Kellgren
KM4BOR
Old May 11th, 2016, 04:41 PM
300Tdi doesn't have a gasket either. It uses RTV type sealant too. I think the service manual calls for Hylomar 2000. Right Stuff would be a good US substitute.
Old May 11th, 2016, 07:14 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
nice, thanks. Clearly haven't pulled it yet but it is leaking.
I just did the 300tdi starter swap. was easy. Sending my spare old alternator out for a rebuild to see if I can get it above the 85 output.
Old May 26th, 2016, 01:43 PM
defeyago's Avatar
defeyago
Santiago
´96 Defender 110 VGTdi SW County
Remember that if I can help you out from down here would be a pleasure. Land of Tdis and 2.8 TGV Ford Rangers. As we say here "we are lucky to find MWM-International parts even at the drugstore" all over the country. Also many parts are even made here, other ones in Brazil.
I ´ve sent some parts for someone up there before.
Cheers,
SANTIAGO
´97 Defender 110 Tdi SW
´04 Freelander Td4 5 dr.
´97 Alfa Romeo 146 TD (Sold)
´95 Volvo 850 GLT Estate
´94 Discovery Tdi (Webasto equipped)
Old December 4th, 2016, 10:52 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Sprung an exhaust leak at the exhaust manifold>head. Anyone know the part number for the exhaust manifold gasket or if it crosses over to the 300tdi?
Semper Fi!
Old December 5th, 2016, 12:08 PM
Intake and exhaust both 300tdi
Mark Kellgren
KM4BOR
Old December 5th, 2016, 12:25 PM
4WARD4X4
Stephan Dennig
Defender 110 MY 2013
Dear Guys,
did anybody know if the TGV 2.8L. is still available ?
Many thanks in advance.
Kind Regards
Stephan
Old December 5th, 2016, 02:31 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
International isn't making them anymore. But you can still find them.
M&D sells them but I believe they are an assembly of parts using both 2.8 components and 300Tdi components. So not a 100% HS2.8.
I could be wrong on that though. Someone higher up the food chain might chime in.
Sent from my iPhone 7Plus using Tapatalk
Black Rhino Lives Matter
Old December 5th, 2016, 05:21 PM
All correct
Sent from my SAMSUNG-SM-G891A using Tapatalk
Mark Kellgren
KM4BOR
Old December 5th, 2016, 05:33 PM
johan's Avatar
johan
johan
2009 Range Rover
International isn't making them anymore. But you can still find them. M&D sells them but I believe they are an assembly of parts using both 2.8 components and 300Tdi components. So not a 100% HS2.8. I could be wrong on that though. Someone higher up the food chain might chime in. Sent from my iPhone 7Plus using Tapatalk
There is at least one new one somewhere 😜😜
After production stopped somewhere in 2008 or 2009, if forgot the exact date but can look it up, the license of this engine (and the 300Tdi )was sold to a Chinese company.
Should have the details somewhere. Don't know if it ever went in production maybe somebody good with Google can find this out.
Johan
Old December 5th, 2016, 07:04 PM
They can still be found new here and there as old stock
Mark Kellgren
KM4BOR
Old December 5th, 2016, 11:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
Exhaust/Intake manifold gasket, LR part number: ERR3785
Semper Fi!
Old January 1st, 2017, 08:46 PM
A range rover BMW serpentine belt, part no LR051050 is actually a perfect fit for the 2.8
Mark Kellgren
KM4BOR
Old January 2nd, 2017, 04:20 AM
4WARD4X4
Stephan Dennig
Has anybody an Idea where I can buy a new 2.8L TGV Engine in Europe?
Old April 21st, 2017, 04:59 PM
AgRover's Avatar
AgRover
Adin
1997 Defender 90 SW Badge #2493
Has anyone replaced the 2.8 TGV alternator with attached brake vacuum pump (85 amps) with a higher performing 300 Tdi alternator (100amps or greater) and AN electric vacuum pump mounted elsewhere? If so please post the part numbers required for the swap and any info on where the parts may be found along with any helpful hints to do the work. Thanks!
diesel, part, parts
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
Is there a list of common parts from D1 to Defender? btate Defender Technical Discussions 1 February 16th, 2009 10:49 AM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
Diesel exhaust parts JimC Defender Technical Discussions 0 November 3rd, 2004 09:01 AM
