2.8 TGV Turbo Diesel common parts listing - Page 2 - Defender Source
Old February 19th, 2013, 01:40 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Originally Posted by Overlander View Post
Good to know. when I looked up that part no, it was listed as common to Chevy, Mercedes and Fords. I also pics of one that still had same size battery rings and a blade trigger, so perhaps it varies.
My understanding is that the 300 TDI starter complete fits right in though if there's a desire to stick with LR part numbers. anybody understand differently?
Starter or solenoid? Solenoid definitely not.
Old February 19th, 2013, 01:44 PM
I was referring to the whole starter assembly
Mark Kellgren
KM4BOR
Old February 19th, 2013, 02:00 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Send me one and I'll tell you....
Old August 11th, 2013, 04:53 PM
andyrad
Andy Radlgruber
None.
Can anyone tell me if the radiator/intercooler assembly is the same. I bought someones 94 with the 2.8 installed and the hoses are all over the place, not like it should be, because there is an aftermarket intercooler bolted to the front end. The fan is gone and there is an electric fan bolted to the rad but not connected. I am going to make a winter project out of getting this baby sorted to where it should be and I think I need to start with the radiator and get the plumbing tidied up.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old December 20th, 2013, 08:37 PM
Well I found a little fuel leak this week and today identifed it coming from the fuel pump air hole underneath the diaphragm, which means the diaphragm is on it's way out. With a trip to VA looming tomorrow, necessity leads to experimentation. Thanks to a buddy, I've been able to answer the outstanding question "does a 300TDI fuel pump fit on a 2.8?" The answer is "yes-but"
With a 300TDI pump on hand, I spoke with M&D today, and they advised that a 300TDI pump would fit, but the outlet routing is different requiring a long fuel line, the primer pump lever is interfered by the 2.8 oil filter housing and would probably need to be bent to fit but would likely not be able to function to limitations of the stroke.
The I emailed Pendy, and as usual he was spot on saying he recalls the injection pipes would interfere with the 300TDI diaphragm housing. He was right.
But I had to know. In the long term interest of all of us with 2.8's preferring to pay $50 for a lift pump rather than over $100, and to address the total lack of conversation on the english speaking web on this matter, I proceeded to remove my old pump and install the TDI lift pump.
I had to remove the pipes just to get to the forward lift pump mounting bolts. That was a first for me. I used different colored zipties to remember exactly which pipe went where on the IP. Removing the old pump was very straightforward.
M&D and Pendy both proved right about the TDI pump installation. the primer lever did not need to be bent to install, but it would have to be bent to function. you don't get full downstroke without hitting the oil housing. while the input pipe of both lift pumps are the same (oriented to the bulkhead), the outlet pipes differ. TDI pipe is aligned to the bulkhead as well, whereas the 2.8 pipe is oriented the right front wing (which happens to be were my primary filter is). This required lengthening of the fuel hose connecting lift pump to filter.
On final reassembly, Pendy proved right as the inboard injection pipes interfered with the lift pump diaphragm, which is clearly a little bigger than the 2.8. I spent a good hour removing the pipes, loosening the idiot bracket holding them together so I could reposition them, then repeating that cycle trying to get them to work around the pump and be able to seat on the injectors and IP. What a PITA that was. But with minor reshaping by hand, I was able to do it, and test drive was successful.
Tomorrow we drive to VA, but test drive was successful tonight. I took pictures which I will post next so you can see them side by side. The old one is the 2.8 lift pump (obviously).
Now that I know they fit, I've ordered a spare to keep on board (which I should have done long ago!)
Mark Kellgren
KM4BOR
Old December 20th, 2013, 08:41 PM
Mark Kellgren
KM4BOR
Old May 27th, 2014, 02:33 PM
My starter solenoid cracked coming back from Denver. Age and heat I guess from 4k continuous miles driven. Per M&D confirmation, I'm installing a 300 TDI starter. They said 300 TDI starter solenoid won't fit the 2.8 starter, but a full 300 tdi starter is a straight install.
then I can source a seperate 300 TDI starter solenoid down the road.
Mark Kellgren
KM4BOR
Old May 27th, 2014, 05:33 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Good idea to wrap it in a high heat starter blanket.
Thermo Tec carries a good one.
If you order an extra starter blanket you can wrap your fresh air line to the air cleaner box also to prevent the Mantec piping failure.
legend in my own mind
Old November 22nd, 2014, 06:51 PM
300tdi belt tensioner is the same per this thread:
http://www.defendersource.com/forum/...ad.php?t=33260
Also, the brass boost signal barbed tap on the 2.8 turbo is 1.8" MNPT, and the silicone host attaching to it is 1/4". for those interested in running your lines off the manifold instead of the turbo like me, I replaced the 2 point barb with a single.
Mark Kellgren
KM4BOR
Old January 29th, 2015, 01:00 PM
I used to think that some 2.8 parts were hard to find. I was wrong. There is only one that is made of honest to God unicorn horn. The turbo inlet gasket.
I had to have my 2.8 turbo rebuilt last week, and after it was done, I came to find that my shop would not install the turbo and provide a warranty without a new gasket. Didn't see this one coming at all, when the shop called and said they checked with all their suppliers and couldn't locate the metal turbo inlet gasket. For every 2.8 owner, what you'll find if the day ever comes is that straight from the factory, there is no gasket between the exhaust manifold and turbo inlet; it's metal to metal. But if you buy a new turbo, it will come with a metal inlet and oil drain gasket in the kit. So of course, I check with M&D in the UK. "No sorry don't have them, never did, we don't fit them. You'll have to do some legwork. Good luck mate!".
The 2.8 parts catalogue doesn't even show a gasket for the inlet. So no part number. Told my mechanic and he said "it's got to have a gasket". I had to find one or they weren't going to do the work or honor their parts and labor warranty.
So now I needed to find a part number. Garrett, Maxion, Internal..I didn't care, needed something. I then found an information jackpot out of Spain. Turbomaster has a robust catalogue and shows the gasket part numbers for the 2.8 turbo.
Gasket ( turbine inlet ): 210647
Gasket ( oil outlet ): 210553
http://www.turbomaster.info/eng/garr...24652-0001.php
Now the outlet gasket is easily sourced and common, but damn. That inlet is a beeyoch. So then I started shooting emails to every turbo house in the UK, and trolling the internet. My 110 was now in jail waiting on it's parole. The bond was a turbo gasket. All the UK turbo shops had nothing, never did. "good luck mate!"
I called Garret suppliers all over the US. "no luck, number not found". Then I called guerrera in Florida, who then called his suppliers in S. America, and he came back and said "it's not available seperately".
So now completely out of options, I started going through all the gaskets on turbomaster's inventory looking for measurement match to 210647. And I found one that was really damn close that fits turbodiesel Mitsubishis.
Turbo Gasket T25 T28 TD04-H Intake 1.97" ID part no: 210501
A quick search on ebay, and I found a supplier for that gasket. And their in Texas! So I ordered one to try and match up to my old gasket as a worst case plan B, and I asked about the Garrett 210647. Low and behold, they had one in stock, and only one! Holy Shit! yeah, I ordered that one too. So I had two gaskets on the way. Ordered 2 day priority.
(side story, because I ordered expedited, it went usps 2 day priority, which meant flying from TX to NJ and getting stuck for a week in Winter Storm Juno).
Well got them both in hand today, and headed up to the shop. not only was the aftermarket 210647 a good match (slightly smaller hole by maybe 1mm) but I couldn't tell it from the mitsubishi, so the mitsubishi should be considered an alternate if needed, and is easily sourced overseas due to it being used on multiple Mitsubishi platforms such as the Prado.
The TX shop that makes this gasket is Chinese owned, but they fabricate their own gaskets. I've asked them to offer the 2.8 turbo gasket kit (inlet and outlet) on ebay so I can direct others to order these. I would much rather have a gasket then not. there is no downside. I'll be ordering probably a half dozen to cover hopefully a lifetime of reinstalls. I'm talking truly unicorn horn, unobtanium shiite. I'll post up the ebay auction link if/when it becomes available.
ebay store ID: mpgstore
Name: Great Power Global
Street1: 565 South Mason Road
Street2: Suite 109
City:L Katy, TX 77450
Phone: 713 893 8482
Mark Kellgren
KM4BOR
Old January 29th, 2015, 01:40 PM
I also found out that the 2.8 TGV turbo (724652-5001S) was superceded.
"724652-5001S turbo supercedes 724652-0001 and is also a direct replacement for 724652-0007 Garrett turbos"
Specifications
1.GARRETT Turbo GT2256V
2.PartNo.:724652-0001,724652-5001S
3.Application: Iveco Renault
Cartridge: 703891-0044
Turbine Wheel: 434882-0013
Compressor Wheel: 702486-0010
Backplate / Sealplate: 703682-0057
Bearing Housing: 703881-0001
Piston Ring: 400749-0006
Thrust Bearing: 728720-0001
Journal Bearing: 729952-0002
Thrust collar: 434677-0001
Retaining ring: 400353-0015
Mark Kellgren
KM4BOR
Old January 29th, 2015, 04:12 PM
Is there a way to get gasket material and DIY?
I know that sounds like a bad idea but.....
Plan B: the Brazilian Ford Ranger came with that 2.8 powerstroke Diesel. Between Brazil/Costa Rica/Honduras etc were it was sold, you might get lucky.
Old January 29th, 2015, 04:19 PM
DIY? no. it is a crush gasket, not flat.
Regarding Plan B, you are about 150 miles behind me on the highway and it is a long painful road. Unless you speak portugese, that is a dead end.
ID:	112282   Click image for larger version
Mark Kellgren
KM4BOR
Old January 29th, 2015, 05:41 PM
Lots of Brazilians here. Even my cleaners Brazilian.....
Old January 29th, 2015, 06:54 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Don't even go near the wax...
Old January 29th, 2015, 07:10 PM
Kellgren is looking to go Brazilian?
First fruity drinks, now this.
-Jeff
I image googled "man brazilian wax" to find a witty response to your comment Jeff. I regret that and highly discourage others from ever putting those words together in a google search.
Mark Kellgren
KM4BOR
Old January 29th, 2015, 08:58 PM
Matt_110's Avatar
Matt_110
Matt
110
Good to know! Thanks for doing the leg work. Only 500 miles on my TGV but I'm sure it will need this eventually.
1987 110, 2.8TGV, ZF Auto
Old January 30th, 2015, 10:43 AM
Ok, as stated, I asked them to put together an inlet/outlet combo auction for the 2.8 turbo gasket, and here it is. First 6 grabbed by my buddy and I to have as spares. If you have a 2.8 turbo, you might want to grab these while their available. Hopefully, there's enough interest to motivate them to keep these in stock.
ebay item number: 381134540899
http://www.ebay.com/itm/381134540899...%3AMEBIDX%3AIT
Name:	tgv gaskets 201647 combo.jpg
Mark Kellgren
KM4BOR
Old January 30th, 2015, 12:49 PM
Jeff at Turboauto in Nashville has all the info to rebuild a 2.8 TGV turbo and has a turbo rebuild cartridge in stock if anyone needs a major rebuild. His prices are very competitive as well.
http://turboauto.biz/
turboaut@bellsouth.net (email on website is wrong)
Mark Kellgren
KM4BOR
Old March 1st, 2015, 05:21 PM
andyrad
Andy Radlgruber
None.
Mark, I am overhauling the engine bay on my 2.8 installation to make it as right as possible and am wondering about the fuel lift pump and fuel filter assy. My truck arrived with the 2.8 frankensteined into place and I have purchased an OEM 300 tdi fuel filter assy to replace the Volvo assy, which has a little hand pump primer on the top. I noticed there is no primer lever on the 2.8 fuel lift pump and am wondering if the 2.8 lift pump will prime the system after installing the 300 ti filter assy or if I should stick with the Volvo assy so I can prime the system.
diesel, part, parts
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
Is there a list of common parts from D1 to Defender? btate Defender Technical Discussions 1 February 16th, 2009 10:49 AM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
Diesel exhaust parts JimC Defender Technical Discussions 0 November 3rd, 2004 09:01 AM
