2.8 TGV performance tweaks - Defender Source
Old August 24th, 2011, 09:17 PM
Post up here what you've done to improve on your 2.8 performance!
Santiago, you go first.
Old August 25th, 2011, 01:41 AM
defeyago's Avatar
defeyago
Santiago
´96 Defender 110 VGTdi SW County
I´m off my house on a trip for a couple of days and since the list is pretty long I´d rather write up later on when I´ll have the time to do it right. I will, I promise. In the meanwhile I wouldn´t bother to hear other guys opinions also.
My engine, anyways, is a stock 2.5 300Tdi with some "periphericals" from the 2.8HS TGV and other tweaks.
Cheers,
SANTIAGO
´97 Defender 110 Tdi SW
´04 Freelander Td4 5 dr.
´97 Alfa Romeo 146 TD (Sold)
´95 Volvo 850 GLT Estate
´94 Discovery Tdi (Webasto equipped)
Old August 25th, 2011, 01:16 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
full width intercooler, moderately tweaked fuel and smoke. I've converted to aluminum coolant tank and fuel return/breather. But that's more ricer.
Other than that, I've put the truck on a weight diet lately.
Old August 25th, 2011, 07:01 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I tweaked the timing a little bit (advanced) with the new belt.......probably didn't notice eh? I thought it smoked less, and revved a little quicker.
Matt Browne
Old August 25th, 2011, 11:45 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Matt, to advance the timing did you do it inside the FIP or a full notch on the belt? Haven't looked at doing this at all but I'm increasingly thinking I might have slipped a tooth or something; I've checked nearly everything else I can think of and while it'll be a bit early I figure changing the belt would give me a chance to check that as well.
Old August 26th, 2011, 08:13 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Didn't even notice over the pulley squeal..
Kidding. I do notice a smoke difference.
I've also been fine tuning the trans kickdown and throttle cable positioning. The kickdown vibrates out of position over a few hundred/thousand miles and you lose the sweetspot on the pedal.
Old August 26th, 2011, 08:44 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
yeah, what was up with that. I thought it went away. Shitty quality serp belt I thought, or did the tensioner go bad.
Matt Browne
Old September 1st, 2011, 08:59 PM
defeyago's Avatar
defeyago
Santiago
Sorry guys for the delay.
Mi engine is a plain stock 300Tdi that has had its first rebuild at 50.000 miles ago. The tweaking it has is the following:
.- New refurbished Garret VNT Turbo from the 2.8HS TGV engine (Mercosur´s Ford Ranger). The turbo is set to open at low RPMs and blow to peaks of 1.5bar (22PSI). Some pieces where fabricated to make it look like it was stock from factory.
.- Injection pump from the same engine mentioned before and tweaked on almost every screw it has....
.- Full size Intercooler in front of water radiator (home made using the IC core from the 3.0E Powerstroke engine from Mercosur´s Ford Ranger). It´s one big intercooler.
.- Silicon Hoses all around to not loose any boost.
.- Bigger Air filter than stock to let the air flow better as with this set-up it sucks up a lot of air now. I´ve used an Europiclón EP300 from MANN.
.- All intake hoses have been braided on the outside for them not be sucked in at full throttle.
.- Upgraded and almost free-flow exhaust 2.5" wide all the way from turbo to the tail.
.- Water radiator upgraded to 5 rows core and with "tropical mod" on it.
.- EGT, water, turbo, etc gauges to check on everything.
Cheers,
SANTIAGO
Overdrive for 110 with 2.8 TGV Santiago Defender Technical Discussions 96 March 6th, 2011 09:36 PM
Tweaking my 2.8 TGV engine (ex Td5), How much is "safe"? Santiago Defender Technical Discussions 11 February 3rd, 2010 12:15 PM
2.8 TGV Timing belt DesertRat Defender Technical Discussions 2 February 16th, 2009 07:12 AM
Air filter for 2.8 HS TGV engine Santiago Defender Technical Discussions 10 September 20th, 2008 02:24 AM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
