2.8 service items - Defender Source
Old May 17th, 2007, 12:05 PM
2.8 service items
Who knows what standard service items are commonly replaceable with 300 tdi parts on the 2.8, or easily available locally (ie NAPA) versus ones that are unique? I know about the fuel and oil filter. How about the hoses, injectors, belts, etc?
P.S. forgot to mention about the intake filter. Mine is a standard 300 tdi land rover part, so got that one noted as well.
Old May 17th, 2007, 01:13 PM
Michael
Michael
Discovery 1998
The new injector nozzles, not the whole injector, that replaced the ones clogged up on the runaway diesel had to be special order from California as per D&W Diesel up here in New York State. They mentioned that they were more expensive than the usual ones. Total cost , parts+labor, was about $350. I probably got ripped off, but was in a hurry. What else is new.
Old May 18th, 2007, 07:03 AM
epninety's Avatar
epninety
Dave Haynes
Ibex 240 2.8TGV
One to be aware of, the serpentine belt is NOT the same as either of the 300tdi items.
Manufacturers part number is 7PK1629.
Only vehicles I've found it on in Europe are BMW 535 (E39) and 735 (E38), to 9/98.
Old May 18th, 2007, 09:31 AM
Thanks much Dave. I'm going to compile a list and post it when it's done.
Old May 22nd, 2007, 07:08 AM
Michael
Michael
Discovery 1998
Part No. IFIKBAL-90P37
service
2.8 HS diesel service manual Overlander Defender Technical Discussions 17 June 10th, 2008 10:25 AM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
105,500 emission service? Chaucer Defender Technical Discussions 0 June 12th, 2005 11:19 PM
service engine light Milo Defender Technical Discussions 3 September 5th, 2004 09:58 PM
30K Service Question WCURoverD90 Defender Technical Discussions 7 April 17th, 2004 10:52 PM
