2.8 Power Stroke A/C setup - Defender Source
Old June 6th, 2010, 10:31 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Anyone have a pic or 2 of the compressor setup on a 2.8 powerstroke? Seems like a standard 300tdi compressor does nor bold right up to the engine without hitting the injector pump..
Legend in My Own Mind.
Old June 6th, 2010, 01:47 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
I bet you could twist IP internals and drill the pre-marked holes on the oil pump body to make the IP fit sideways like on 300tdis do. I guess you should get 300tdis Inyectors piping though, and fill the now not used 3 holes to make everything water tight.
Im not sure if it could be done, Im just throwing ideas but I did something similar. I used a 2.8 Powerstroke IP on my 300tdi and positioned it sideways like the old 300tdi IP goes. Previously I took it to a IP specialist and they twisted the internals to be able to be positioned like the 300tdis one. The good thing is that I didnt have to change any piping.
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old June 6th, 2010, 04:26 PM
johan's Avatar
johan
johan
2009 Range Rover
The injection pump on 300Tdi is rotated and thats why on your engine the compressor hits the pump.
I fitted some adjuster to put the compressor a little higher, this also results in fitting a longer belt.
I have some adjuster left if you are interested. Try to post some pictures tomorrow or so.
Johan
Old June 6th, 2010, 05:44 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Randy, what pic do you need? of the mount itself or the IP?
Old June 6th, 2010, 06:01 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Randy, here you go. I think the 300tdi compressor mount works ok as it is pretty thick. It is what I used on Mr Marchands rig (forgot I had pics of that).
The current 2.8 install has been on hold for a couple of weeks, but if I can remember to fiddle with it I can check the fit.
Name:	Copy of P4250346.jpg
ID:	28316   Click image for larger version
Matt Browne
Old June 6th, 2010, 06:08 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
not sure how I screwed that up, but here is the other picture. I don't recall having clearance issues.......but then again there are many things I don't recall
Matt Browne
Old June 6th, 2010, 08:29 PM
I'm in CT until Tuesday, but can take a pic of my setup if still needed. I fly out again Tuesday night, so let me know.
Old June 6th, 2010, 08:54 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I think Johan is on the same page as me. THis is the compressor I am talking about mounting... Not the one with the rear fittings..
Old June 6th, 2010, 08:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Old June 8th, 2010, 09:03 AM
johan's Avatar
johan
johan
2009 Range Rover
attached some pictures of the compressor on the 2.8.
There are different compressors but as far as I know all of them have the same problem on a 2.8
ID:	28364   Click image for larger version
Johan
Old June 10th, 2010, 07:50 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
The compressor I installed on MR Marchands rig worked without issue as is the same compressor going on the current install. Rear hose, vertical mounting bolts, uses factory compressor mount. I'll look for part #
The compressor Johan has pictured is the same as the V8. Has horizontale montings. Can be fit but needs to be spaced up and comes very close to bonnet underside. Has the monts that M&D used to sell for V8 to 2.8 diesel conversion.
Matt Browne
Old June 11th, 2010, 07:00 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Matt, M&D got back to me. They have a specific mount for the newer 300tdi style (side exit Hose) compressor like the one in my picture. The kit comes with the longer belt as well... $65. I guess its not worth fiddling with.
Old June 11th, 2010, 09:32 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
I'd say that's the ticket then eh? Haven't had to mess with one of the newer compressors yet. Still have a couple of kits left with the older compressor.
Matt Browne
300 tdi with a/c loses power discotdi Defender Technical Discussions 10 July 17th, 2008 10:18 AM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
» Defender Registry
Casper
JimScott
Max
juddy
Add your Defender
