2.8 charging issue - Defender Source
Old July 19th, 2014, 09:19 PM
2.8 charging issue
So here's a recent electrickery issue that's I'm stumbling through. a few weeks ago my alternator started acting up. when I start my truck, there is no movement in the voltage, and my tach is dead. It stays that way when I start driving til I get about 2500 rpm or so, then it comes alive, as well as the tach. it'll stay that way til I shut down. When I start back up, same thing. it's consistent.
Any idea? I just replaced the regulator with a fresh one. no change.
Mark Kellgren
KM4BOR
Old July 19th, 2014, 10:14 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Loose connection or shorted wire? Just guessing. I don't like messing with wires.
Black Rhino Lives Matter
Old July 20th, 2014, 12:20 AM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Sounds like an internal diode failure or too much resistance in the power cable. What voltage are you seeing before 2500 rpm? After?
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old July 20th, 2014, 10:17 AM
just battery voltage. 12.4-5 volt. then it pups right up to 14. doing research it sounds like there is an issue with the exciter curcuit for the low voltage lamp, and I dont think my warning lamp has ever worked. Im goung to trace it down today.
Mark Kellgren
KM4BOR
Old July 20th, 2014, 05:35 PM
Resolved! Got a great self education on how an alternator works in the charging system. Turns out my D+ connection from alternator to Low Voltage Warning Light broke at the connector on the alternator. So no warning lamp illumination when you turn ignition to position II, and then no immediate jump in voltage after start combined with warning lamp extinguishing is the symptom for loss of continuity to D+.
Quick replacement of the female connector and I'm good to go. (it's a beeyoch to get to D+ on a 2.8 btw with that vacuum pump in the way).
Another symptom-resolution combo in my tool chest.
Mark Kellgren
KM4BOR
Battery charging solutions Treuwer Defender Technical Discussions 3 January 13th, 2010 03:52 PM
Charging AC in a 97 artm Defender Technical Discussions 2 August 18th, 2009 11:33 PM
UPS charging customs duties and brokerage charges cgalpin Misc. Chit-Chat 7 November 26th, 2008 09:09 AM
Dual Battery Charging RBees Defender Technical Discussions 5 January 4th, 2007 08:51 AM
Battery Charging chris snell Defender Technical Discussions 3 November 29th, 2006 12:20 PM
