2.8 and snorkel - Defender Source
Old November 16th, 2005, 04:32 PM
pcarey's Avatar
pcarey
Peter Carey
'93 NAS Defender 110 #322
2.8 and snorkel
Does anyone have any pictures of the routing of the air intake on a 2.8 when attached to a Mantec snorkel?
I've got the engine on order but I'm just trying to figure out the best way to route it out with the least amount of bends. From the photos I've seen, it looks like the intake on the engine will sit just back from the fender vent, meaning it'll have to pull a 100 degree bend one way and then the other to make it out.
thanks
pwc
Old November 16th, 2005, 06:23 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
The air filter has two inputs, one in the rear and a second that comes off the side at a 45? angle. The line to the rear is for the turbo. The snorkel line is the one with the metal heat shield, it is routed behind the engine and into the side of the air filter.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old November 16th, 2005, 06:31 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
David, thanks for the diesel porn. (Note to self... wipe off chin and get back to work.)
Insert pithy quote here.
Old November 16th, 2005, 06:32 PM
pcarey's Avatar
pcarey
Peter Carey
nice! thanks sheki!
pwc
Old November 16th, 2005, 08:05 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
LOL I couldn't have said it any better!
Old November 16th, 2005, 08:18 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
More.... I have the southdown. hose runs underneath along the top of the bellhousing to the intake on the bottom of the air cyclinder...
Old November 17th, 2005, 12:09 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Damn you two!!! Why do you have to tease me like that!!
Jimmy Buffett
Old November 18th, 2005, 10:09 AM
pcarey's Avatar
pcarey
Peter Carey
Thanks David, Was it tough getting the hose under and around the brake master?
Also, what kind of insulation did you go with on the underside of your hood?
pwc
Old November 18th, 2005, 10:30 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. mine is a 300tdi with no snorkel yet but I am jelous and wanted to add so good porn for you guys..
Legend in My Own Mind.
Old November 18th, 2005, 10:41 AM
roverboy's Avatar
roverboy
Thomas
Booger
Factory 300 Tdi here. Maybe this will help.
"There is absolutely no excuse for the way I'm about to act."
Old November 18th, 2005, 04:13 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
You people are cruel!!
David, did you ever get that thing registered in california???
Old November 18th, 2005, 11:37 PM
sheki's Avatar
sheki
David Shechter
Hey Arbi,
Yes it is registered as a diesel in CA, had no trouble what so ever with the process.
Old May 27th, 2010, 02:17 PM
Does anyone know what the cfm requirement is for the 2.8 TGV? I have a donaldson prefilter I purchased a long time ago, and want to determine if the model I have is sufficient for this engine requirements.
I used an online calculator and it came up with 561 cfm for a general turbo diesel with the 2.8 displacement at max rpm. if that's the case, then the peak requirement for a donaldson is a 4" inlet per the donaldson reference charts. My Mantec snorkel is a 3", which means that my engine is limited by not only the prefilter, but also the mantec snorkel.
any thoughts/facts appreciated.
Old May 28th, 2010, 06:33 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I would likely try to keep the size of the hose comparable to the size going to the turbo as that is the "final common pathway".
The other option is to make with a quick disconnect and use it only when you have to, ie water crossings/very dusty trails.
Old May 28th, 2010, 06:56 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
561 is too much. It should be around 350/380 at the most.
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old May 28th, 2010, 07:13 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Sorry to hijack but does anybody know what the max cfm is the 3.9/4.0L runs?
Old July 22nd, 2010, 03:59 PM
Does anyone know a good place online to get heat shielding like he is using on his snorkel tubing?
snorkel
Building my own snorkel - JackW Defender Technical Discussions 7 March 6th, 2006 01:39 PM
Yet another snorkel question gtg067i Defender Technical Discussions 4 June 30th, 2005 05:04 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Cheapest place to buy Tuffy console, Mantec snorkel Chris Cox Defender Technical Discussions 7 March 14th, 2005 09:21 PM
Genuine Land Rover Snorkel STC5065 lrnasd90 For Sale - Parts 15 September 28th, 2004 06:28 PM
