2.5td wont start unless pump bleed screw open - Defender Source
Old June 29th, 2013, 03:40 PM
msomers
Matthew Somers
1986
My 2.5TD has developed a weird fault. It will only start if I open the bleed screw on top of the Injection pump and close it when it starts. It runs well at tick-over and at higher revs, but when I stop the engine, even when its warm, it won't start unless I open the bleed screw again and it starts instantly and runs well. I've replaced fuel delivery and return pipes from tank to lift pump, filter, injection pump and back to filter. New copper washers everywhere, new boost diaphragm. Bled system manually,and using engine. Plunger removed from solenoid. Still won't start without opening the bleed screw on pump. Can anyone help?
Old June 29th, 2013, 04:02 PM
Is the lift pump working?
Old June 29th, 2013, 04:06 PM
msomers
Matthew Somers
1986
Yes, new Delphi lift pump fitted
Old June 29th, 2013, 04:15 PM
And you have verified it is working?
Old June 29th, 2013, 04:17 PM
Pu might have a small leak at a fitting letting some air in.
Old June 29th, 2013, 04:32 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Air Leak
John is right in that you have an air leak.
if you mount a 12V pump back near the tank, it will pressurize the fuel system and expose the leak which is actually an opening allowing air into the fuel system.
RDavisinVA
Old June 30th, 2013, 10:48 AM
msomers
Matthew Somers
1986
Yes john, lift pump working
Will now check the new connections i've made on fuel line. The srange thing is that it will not re-start even after a couple of seconds unless I open the bleed screw. If I have to rig up a 12v pump, do I connect it straight on to the pump inlet, and does the solenoid plunger need to be open?
Old July 1st, 2013, 09:50 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You wire the 12V fuel pump to have power when the IG key is switched on.
Locate it near or midway down the main frame rail.
Not sure what this means: "do I connect it straight on to the pump inlet, and does the solenoid plunger need to be open?".
RDavisinVA
Old July 1st, 2013, 03:05 PM
msomers
Matthew Somers
1986
Robert,
I misunderstood what you meant. I thought you meant connect the 12V pump direct to the injection pump to pressurise it. I now realise you meant just by-pass the mechanical lift pump and test the whole system. I have ordered a 12Vpump. and will let you know if I find the problem. Thanks for your assistance, I was running out of ideas.
Old July 1st, 2013, 05:29 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
No no no...
Robert,
What I meant was to install the 12V fuel pump somewhere along the main rail.
This means inline with the fuel line running along the main rail. Very simple.
No need to over complicate the scenario.
It doesn't replace or by pass anything.
Just put it in place and wire it to pump when the key is on.
I use the Airtex 8012S.
RDavisinVA
Old July 1st, 2013, 06:37 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
This.
Just got my 2.5 running following this rdavis formula:
Fuel Tank---->Fuel Line---->Sedimenter---->Fuel Line---->12v Fuel Pump (Airtex 8012S)--->Fuel Line----->Stock LR mechanical Fuel Pump ---- the rest of the stock LR fuel path
The 12v pump exposed immediately that I didn't have the fuel filter tightened down enough.
The only question I have on the fuel pump is it came with a mini fuel filter. I took it off looking at prior pics and with the sedimenter I would think that would be fine, but there is a big ol' label saying the pump's warranty is dependent on using the filter?
Old July 2nd, 2013, 02:53 PM
msomers
Matthew Somers
1986
Thanks everyone for very helpful responses. I take it that the 12V pump will pump straight through the lift pump and won't damage it.
bleed, start
No Start, High pitched noise from Engine compartment jhhorse Defender Technical Discussions 9 February 8th, 2013 05:44 PM
Strange Fuel Pump Fuse Problem mhill Defender Technical Discussions 6 July 11th, 2005 04:23 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
