2.5td Turbo Whine - Defender Source
Old July 31st, 2016, 02:48 PM
Oasisplayer311
Eric Hayes
2003 D2
2.5td Turbo Whine
So my newest rebuilt turbo has some play in the prop shaft which I'm not sure is good or not. It only makes a strange whine at the top end, and the play in the propeller is slight.
Not sure if I should be worried or not, new fuel diaphragm and the air pipe to the turbo was free of diesel. Turbo sounds fine unless I'm running 70 with my foot pressed down to the floor, or hitting really high revs.
Honestly just trying to make it back to TN from CO, and would love to not worry about this till I get back
Old July 31st, 2016, 03:08 PM
No way to diagnose by way of fingers. If your impeller isn't hitting the walls of the turbo, it's all you can do.
If you're worried, then just unscrew the wastegate and drop the boost to low levels - 1-2 psi or so.
What boost pressure were you running the turbo at?
Either way, just dump the exhaust through the wastegate and ride it home.
If your impeller isn't hitting the walls of the turbo, it will last a trip from CO to TN at low boost levels with no problems. The takeaway is this: The probability of destroying your turbocharger is an exponential function of impeller velocity. Impeller velocity is a complex but increasing function of boost pressure and airflow. If you have any suspicion or fear of turbocharger failure at any point and want to minimize additional damage, then you must simply reduce the boost pressure.
Old July 31st, 2016, 03:22 PM
Oasisplayer311
Eric Hayes
2003 D2
No way to diagnose by way of fingers. If your impeller isn't hitting the walls of the turbo, it's all you can do. If you're worried, then just unscrew the wastegate and drop the boost to low levels - 1-2 psi or so. What boost pressure were you running the turbo at? Either way, just dump the exhaust through the wastegate and ride it home. If your impeller isn't hitting the walls of the turbo, it will last a trip from CO to TN at low boost levels with no problems.
Low boost would be turning the waste gate to the "left" (extending the waste hate arm) correct?
Old July 31st, 2016, 03:26 PM
I can't remember which direction reduces the boost, but it's whichever direction reduces the pressure against the wastegate flap.
If you **CAREFULLY** remove the wastegate c-clip (it will go flying if you're not careful, and when it goes flying, it flies to wastegate c-clip heaven), then pull off the wastegate actuator from the flapper arm. When the wastegate flapper swings away from the hotside, it's open, and you just want to make it easier for the flapper to open.
Old July 31st, 2016, 04:05 PM
Oasisplayer311
Eric Hayes
2003 D2
I can't remember which direction reduces the boost, but it's whichever direction reduces the pressure against the wastegate flap. If you **CAREFULLY** remove the wastegate c-clip (it will go flying if you're not careful, and when it goes flying, it flies to wastegate c-clip heaven), then pull off the wastegate actuator from the flapper arm. When the wastegate flapper swings away from the hotside, it's open, and you just want to make it easier for the flapper to open.
Yeah, that stupid c-clip lol. Whenever I pulled it off, extending the arm gives it "less" resistance, so I'm guessing that's reducing the boost. Key word here "guessing"
2.5TD Turbo / 2.5TD Air Box and Bracket LakeLBJ For Sale - Parts 1 May 20th, 2016 10:05 PM
Right front wheel whine kolvedic Defender Technical Discussions 33 November 2nd, 2011 10:30 AM
Supercharger Whine/Noise gtg067i Defender Technical Discussions 1 December 23rd, 2006 06:29 AM
Transfer Case Whine outfield Defender Technical Discussions 12 July 4th, 2006 11:42 AM
Whine anyone? Quimbola Defender Technical Discussions 13 December 15th, 2003 05:25 PM
