2.5TD/LT77 to 200TDI/R380 Replacement Advice - Defender Source
Old July 12th, 2014, 07:48 AM
richord
Richard Ordowich
1987/D90
After some wise advice on this site I am considering replacing my 2.5TD/LT77 with a 200Tdi/R380.
I will be doing a compression test on my current engine and based on the results, I will make my decision. It runs fine, a bit of white smoke when starting but otherwise it doesn't smoke but my air filter gets black from the breather after only a few hundred miles.
I just put in a temporary catch can off the breather to see what happens and was thinking of installing a Provent 200 vent system. But I think I am may be spending money on a lost cause.
I have looked at various sources for the engine such as Urban Land Cruisers and was wondering if anyone had any suggestions for sources for this engine and transmission.
I was planning to do the swap myself but not sure how big a job it is and any advice or pointers of links to sites who have some details about this swap out are appreciated. I have done a lot of work on this truck already; changed the timing belt, water pump, suspension parts etc. and have all the tools except for an engine hoist.
Old July 12th, 2014, 08:06 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I may have time to do swap for you.
Legend in My Own Mind.
Old July 12th, 2014, 08:31 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I assume you are referring to a R 380 stumpy? If you go that route the swap is relatively straight forward. What's the ratio in your transfer case? If its a 1.4 you are good.
Old July 12th, 2014, 08:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Abe, if it is stock, Richard has a 1.6.
RDavisinVA
Old July 12th, 2014, 08:54 AM
solarguy's Avatar
solarguy
Abraham Bell
That's what I thought.
Old July 12th, 2014, 10:01 AM
with a non cross drilled input gear
Old July 12th, 2014, 01:10 PM
richord
Richard Ordowich
1987/D90
I believe the truck is stock. What difference will the transfer case ratio make? If it it's stock, can I still install the R380? It is described as a short shift.
Randy, where are you located in New Jersey?
Old July 12th, 2014, 01:19 PM
solarguy's Avatar
solarguy
Abraham Bell
If you have a 1.6 transfer case your rpms will be too high unless you are running large tires.
You can install a r380 stumpy that will allow you to do the swap with out moving the motor mounts. It will bolt up to your transfer case but unless you have a 1.4 or higher the rpms will be to high.
200tdi, ac, advice, r380, tdi
R380 Vs LT77 - Real World Differences? turbodave Defender Technical Discussions 53 October 24th, 2015 09:54 AM
2.5TD with LT77 rherl For Sale - Parts 22 November 2nd, 2013 06:24 PM
Defender 200tdi and 300tdi engine kits w/ LT77 or R380 ZombieMotors For Sale - Parts 0 September 10th, 2013 03:42 PM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
UK rebuilt LT77 R380 FS SafariHP The Vendors Loft 0 June 11th, 2008 05:46 AM
» Defender Registry
White
KGH
Lloyd
rtcgb
Add your Defender
