2.5TD Cracked Exh Manifold? Missing Stud... - Defender Source
Old April 25th, 2015, 04:51 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
While digging around under the hood I noticed what looks to be a crack in the exhaust manifold...If someone has one that they can check to see if it is a crack just prior to the the second outlet joining the manifold.
If it cracked, it may be because of the tab missing to hold it against the head...
I found the tab that holds the inlet and exhaust manifold to the head and see that the stud is missing...the hole looks to be in good shape and I wonder if the stud either fell out or was never put back in....
Anyone have a stud and an exhaust manifold that they would like to sell?
ID:	119181   Click image for larger version
ID:	119183   Click image for larger version
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 25th, 2015, 06:18 PM
That manifold is toast. Hopefully someone here has an exhaust manifold they will sell you.
Old April 26th, 2015, 06:57 AM
hcdmueller
Chris Mueller
88 D-90
I have a manifold and stud if you are interested, but you will have to wait a couple weeks. I am out of the country.
Old April 26th, 2015, 09:17 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Thanks Chris!
ac, rack
Does one stud match up for another stud? airbornrover Defender Technical Discussions 2 May 11th, 2011 09:46 AM
Broken exhaust manifold stud cgalpin Defender Technical Discussions 30 December 14th, 2008 02:02 AM
Place your bets, Blown head gasket, or cracked manifold? Hans Defender Technical Discussions 12 March 20th, 2008 08:02 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
Cracked Cat - fix? (pic) wicks Defender Technical Discussions 14 May 20th, 2004 12:17 AM
