2.5TD Boost Pressure? - Defender Source
Old March 22nd, 2015, 06:35 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I just installed a VDO 15 psi boost gauge and I "T"'d into the pipe running from the turbo to the injector pump...I am seeing just about 7psi before if falls off...I thought I had seen over 8psi for this engine...it's relatively low mileage (83K)...if it is a a few psi low should I adjust the waste gate rod to get a tad more pressure? I am not looking for Porsche 930, but I do want all of the boost I am entitled to.
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 22nd, 2015, 08:34 PM
richord
Richard Ordowich
1987/D90
My pressure was down that low before I replaced the boost diapragam. Mine had a small pin hole in it.
Now it goes up to 10 and does not drop off. Made a big difference in engine performance. Cheap part and 15 minute fix.
"Slow down and smell the diesel"
Old March 22nd, 2015, 08:52 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Mine is pretty corroded on the outside so I was thinking that may be a good thing to start with...
Old March 22nd, 2015, 09:35 PM
The workshop manual says 9.3 psi.
Old March 22nd, 2015, 10:28 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You piped into the alda T which is not optimal.
You need to plumb into the inlet manifold.
RDavisinVA
boost
2.5TD 19J Turbo Boost Pressure Numbers? richord Defender Technical Discussions 1 August 25th, 2014 02:19 PM
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
300TDI Boost Pressure tmodler Defender Technical Discussions 15 August 24th, 2011 09:47 PM
2.5td heavy breather CDNRover Defender Technical Discussions 18 April 6th, 2009 05:59 PM
2.5td CDNRover Defender Technical Discussions 0 October 14th, 2008 02:01 PM
