2.5TD 19J Turbo Boost Pressure Numbers? - Defender Source
Old August 25th, 2014, 02:15 PM
richord
Richard Ordowich
1987/D90
I installed a boost gauge and was wondering what I should see on the gauge while driving. I understand the principles of how a turbo works but not sure why my boost seems to vary based on what gear I am in. Is this normal?
In first gear the boost increases and then when the accelerator pedal is about 2/3's of the way down, the boost drops off. In Second gear the boost continues all the way up to about 10 and stays there as long as I keep the accelerator down.
Should the boost increase in all gears and peak out at around 10?
Old August 25th, 2014, 02:19 PM
jafir's Avatar
jafir
Jafir Elkurd
Probably less load on the engine in first gear?
boost
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
19J pressure buildup grapplerdan Defender Technical Discussions 22 July 18th, 2014 10:39 AM
2.5TD (19j) onto Series III transmission SkinlessFrank Series Technical Discussions 5 July 9th, 2013 02:28 PM
Thoughts on a 2.5TD 19J tomaco1 Misc. Chit-Chat 1 December 5th, 2010 08:47 PM
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
