2.5ns breather cap ? - Defender Source
Old July 27th, 2015, 06:59 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
My exmod is equipped with the 2.5na diesel. When I got it, the breather cap had a hose running off it to the left side of the engine. It blew a ton of oil out of the hose and onto my diff while driving home from the border after I got it imported.
Looking into it, I see the hose is supposed to run to the right side of the engine into what looks like a filter then down into the pan. What the heck is this part and should oil flowing through the breather cap be a huge concern if it's obviously supposed to run back into the engine?
Old July 27th, 2015, 07:22 PM
The Dro
Dro
1988 Ninety
It should go to the air intake box.
Some folks install an Air/Oil Separators.
Old July 27th, 2015, 07:24 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Brian:
You're not putting that engine back in are you?
RDavisinVA
Old July 27th, 2015, 07:25 PM
jafir's Avatar
jafir
Jafir Elkurd
I think the military put centrifugal filters on them to keep them from breathing their own oil and running away.
Old July 27th, 2015, 07:30 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Originally Posted by rdavisinva View Post
Brian:
Wish I had another option but right now I just want to get it back on the road. Goal is to put some cash aside for a repower in a year or so.
Old July 27th, 2015, 07:35 PM
jafir's Avatar
jafir
Jafir Elkurd
CYCLONE BREATHER 2.5 DIESEL 90/110, RNL434, ERR1471 - Rovers North - Classic Land Rover Parts
------ Follow up post added July 27th, 2015 06:44 PM ------
Actually, the military part is different from what I posted:
ERR2886 - Breather Cyclone Military Engines 2.5D
Old July 27th, 2015, 07:51 PM
jafir's Avatar
jafir
Jafir Elkurd
And the other part on the military setup: ERR1468 | Valve
Old July 28th, 2015, 12:14 AM
bish1865
Bruce Bishop
1985 Defender 110
Looking at the picture Your diaphragm pluming is wrong, The side port on the diaphragm goes to the cyclone below. The other port in the middle of the diaphragm routes to the intake manifold. I had the same issue when I bought my 110. It was consuming it's own oil supply. I found a picture of another 2.5 NA and saw the diaphragm routing was different. I tried the other way no more problem. The cyclone should route down to the oil pan for return.
Old July 28th, 2015, 12:21 AM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
The photo is from withams. Mine had none of that plumbing, just a hose running from the breather cap to the floor.
How much blow by is acceptable before you start thinking rebuild or replacement?
Old July 28th, 2015, 12:24 AM
http://i.ytimg.com/vi/EX3rSfy6ebM/maxresdefault.jpg
Should look like that.
Cleaning Oil Breather Cap 2.5TD ETC7774 richord Defender Technical Discussions 1 July 20th, 2014 11:02 AM
Breather valve for fuel tank cbass Wanted 0 March 18th, 2008 01:01 PM
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
axle breather install CHRIS C Defender Technical Discussions 6 March 22nd, 2005 07:59 AM
Greese fittin an breather toob rover4x4 Defender Technical Discussions 4 December 30th, 2003 11:49 AM
