2.5NA Wiring - Help Needed - Defender Source
Old May 4th, 2016, 04:52 PM
ben little's Avatar
ben little
ben little
1986 ex-MOD 110
Nearing the end of my 110 restoration and I cannot seem to figure something out.
There is a single 'green' wire coming off the inside of the injector pump - Where does this connect to?
Can someone possibly post a pic of the loom that it plugs into?
Thanks in advance.
Old May 4th, 2016, 04:59 PM
The only connection to the injection pump should be for the fuel solenoid and it should be white with black stripe which is direct from the ignition switch. Green is switched and fused power.
You can download the factory manual here: pdf Land Rover Manuals | Landroverweb.com Wiring schematics are in there.
Old May 4th, 2016, 06:11 PM
ben little's Avatar
ben little
ben little
1986 ex-MOD 110
Thanks... Yea I've looked through the manuals and my truck seems to have different colors than what the manual suggests. Could be the ex-MOD... Not sure.
The wire is definitely green (solid green IIRC).
Old May 4th, 2016, 06:27 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Can you post a picture of it? Hard to say what you've got going on without seeing it. As John said, there should only be a single connection on the pump.
-Ash
Geared Restoration Co.
352-572-3236
Old May 4th, 2016, 06:55 PM
Originally Posted by ben little View Post
Thanks... Yea I've looked through the manuals and my truck seems to have different colors than what the manual suggests. Could be the ex-MOD... Not sure. The wire is definitely green (solid green IIRC).
I have the MOD wiring schematic and the colors should be the same.
As Ash says a picture might help. Show where it goes.
Old May 4th, 2016, 07:00 PM
Maybe oil temp sensor. It is supposed to be light green with green stripe.
Old May 4th, 2016, 07:02 PM
Here is the MOD wiring diagram.
Old May 4th, 2016, 09:36 PM
ben little's Avatar
ben little
ben little
1986 ex-MOD 110
Ugh... Thanks guys. Good news, I'm just a dumbass - looked closer at this again and figured it out.
The green wire is actually for the oil temp sensor.
wiring
2.5NA Wiring Harness steinhnj Wanted 0 February 8th, 2016 07:51 PM
ignition wiring help needed spartan Defender Technical Discussions 3 June 26th, 2013 02:13 PM
Crankshaft Damper 2.5na Needed edh Wanted 2 January 25th, 2012 07:22 AM
Speaker Wiring Help Needed NoVaKevin Defender Technical Discussions 10 February 14th, 2011 02:49 PM
Radio install/wiring help needed. Firefighter2904 Defender Technical Discussions 5 August 8th, 2007 09:39 PM
