2.5na stop solenoid - Defender Source
Old August 9th, 2016, 11:27 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
2.5na stop solenoid
I have gone through two stop solenoids in 2.5 years w/ one failing as my truck idled this morning. Wondering if there is anything with the injector pump that could be causing this.
My first one was a newer white box one that came on the truck. After it melted, I quickly bought and installed the same aftermarket style one (mfd by Flag Diesel) but went looking for a better one. I located an oem Delphi unit which appears to be a much higher quality product w/ a heavier crimp, etc., but didn't install it. Carried it as a spare...came in handy today.
Could an internal issue with the pump pressurize the fuel at the solenoid? Can't see how from the cutaways...
Running voltage is normal and engine grounds are good so I don't think that is a problem.
Or, is this just the further manifestation of the occasionally craptastic quality of some aftermarket parts?
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old August 10th, 2016, 07:24 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Take the old one to a John Deer tractor supply with an older parts guy who can match it up with the more robust one that they have.
Also think your ignition switch is suffering from burnt contacts or other items added on to the on position that are drawing power (or both).
The better option is to replace the entire slow 2.5 N/A engine if your budget is there.
RDavisinVA
Old August 10th, 2016, 08:01 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Do you use an additive in your diesel? We know the fuel conditions are all wrong for these tractor components so is it possible that the fuel quality is causing issues? I use this stuff in my fuel http://stanadyneadditives.com/lubricity-formula/.
Old August 10th, 2016, 11:59 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks both.
I had an OEM Delphi unit as a spare, it is now on the truck, I got it from Oregon Fuel Injection for $62 vs. $200+ for the LR branded OE part or ~$20 for white box.
The ignition switch thought is great as I have had an intermitted non-start when the key was turned. The glow plug light lit, the brake check relay clicked but the starter relay would not engage or seemed to do so weakly, not the loud 'clack' you'd expect. I checked/serviced all grounds, the ignition and feed connections to the (new) starter, etc. and all seemed fine. Guess I am looking at a new switch. Known to be a weak spot.
I also use the Stanadyne lubricity additive. Thx.
I am considering the 200tdi upgrade, however this is a newly rebuilt 2.5 and a good engine for what it is. Yes it is slow, but for this truck's use, it is adequate. The 3-4 trips to the Cape on 495 are slow, but not too bad..just time the trips and drive on. Heck, I actually passed a few cars the last time.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
top
300tdi no start stop solenoid clicks Broncoduecer Defender Technical Discussions 28 March 7th, 2015 12:22 AM
2.5NA stop solenoid...melted pitchrollyaw Defender Technical Discussions 19 August 13th, 2014 01:50 PM
ARB solenoid connector and switch? MonLand Defender Technical Discussions 3 January 14th, 2007 11:25 PM
300tdi diesel fueling control solenoid Chris Cox For Sale - Parts 1 January 2nd, 2005 07:22 PM
Moving winch solenoid howellm70 Defender Technical Discussions 9 March 25th, 2004 02:05 PM
