2.5NA Starter Motor Issues - Defender Source
Old March 18th, 2013, 05:09 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
So, I have just got back from a trip in the 2.5NA 110, which included its first stateside breakdown. It has been starting without a hitch since I got it, but today it decided to mess about. After stopping for about half an hour at a store in Fredrick I started the 110 up, it started well as always but this time a faint humming sound had me curious. After initially thinking it was the heater fan making noise I turned the ignition off, stopping the engine in the process, but the humming continued.
On opening the bonnet (hood for my stateside friends) it was obvious the starter was still spinning, so as quick dash round the tool kit and a half inch ring spanner to remove the earth cable. After an extensive check of all the wiring (why is it always raining, sleeting, or both when you brake down!) revealed no obvious shorts or defects I deduced that the starter itself was to blame, so in true classic Land Rover fashion I selected the largest adjustable wrench from my tool roll and gave the starter and solenoid half a dozen decent whacks. After gingerly touching the earth lead to the battery resulted in no more high current sparks or immediate spinning of the starter, I reattached the earth lead and turned the ignition key, starting the engine straight away as situation normal.
Anyone else had a similar issue? I've had the solenoid fail to engage the motor on previous Defenders, but never had the starter spin on its own before. Planning to fit a kill switch to the battery cable to enable quick electrical isolation in case something like this happens again.
Old March 18th, 2013, 07:31 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I would think solenoid. But then again...it is a Rover. I have found a local shop that actually does rewinds/rebuilds/ect. Might want to go that route if time allows. The switch is a good idea tho. Can keep from further damage.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old February 24th, 2014, 11:59 AM
Ignotus
gene
1960 109, w/200TDI
I'd be careful about where you put a cutout switch. Some of the charge from the alternator may be going back thru the cable to the battery.
gene
Old February 24th, 2014, 12:54 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If this happens again disconnect the ground cable as before, then put a test light on the white with red lead going to the starter solenoid and the (-) battery post and see if the light glows. If it does you have a bad IG switch, otherwise the solenoid is sticking which is more likely.
RDavisinVA
motor, start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
