2.5na oil pressure sensor - Defender Source
Old February 1st, 2015, 12:55 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
I was wondering where i put the oil pressure sensor on the engine, is it the one by the oil filter? If not can I put some kind of T there to place both the sensors in that same location?
Thanks!
Old February 4th, 2015, 10:37 AM
PabloCocito
Pablo Cocito
Anyone? Or where is pressure sensor located?
Old February 4th, 2015, 10:44 AM
T it.
Old February 4th, 2015, 07:04 PM
PabloCocito
Pablo Cocito
Originally Posted by javelinadave View Post
T it.
Where would it go? Would it be the sensor right next to the oil filter?
Old February 4th, 2015, 07:12 PM
GOOGLE searching is going to ultimately keep people from ignoring your posts. I typed in "2.5NA oil pressure sensor" and found this:
It is one thing to ask for help, it is a completely different thing to not even try to help yourself first. Learn to fish instead of begging for a fish.
Old February 4th, 2015, 07:27 PM
PabloCocito
Pablo Cocito
GOOGLE searching is going to ultimately keep people from ignoring your posts. I typed in "2.5NA oil pressure sensor" and found this: It is one thing to ask for help, it is a completely different thing to not even try to help yourself first. Learn to fish instead of begging for a fish.
I did, I do as much googling as possible, I saw that one, but I also saw that some engines have the sensor in different places..
Thanks though! Exactly what I needed.
Old February 4th, 2015, 07:29 PM
You will also need an extension from the "T" so the pressure sender clears the housing. There is a thread regarding just this if you search thru the tech section.
I'm in a generous mood tonight:
http://www.defendersource.com/forum/...light=pressure
Instead of "T"ing it off you can get a VDO sender that has a 6psi switch to turn off the idiot light and the other powers the gauge.
2.5na oil capacity and dipstick depth pitchrollyaw Defender Technical Discussions 8 September 11th, 2014 07:24 PM
2.5NA oil pressure gauge range pitchrollyaw Defender Technical Discussions 2 May 16th, 2014 10:59 AM
WTB pressure switch sensor for RRC ABS Baja 90 Wanted 2 April 17th, 2013 01:26 AM
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 05:10 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
