2.5NA oil pressure gauge range - Defender Source
Old May 16th, 2014, 09:42 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I will be adding a VDO oil pressure gauge to my 90. What range is appropriate for this engine; 0-80 or 0-100? Based on my Series, I guess it is the 80, but wanted to confirm.
thank you.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old May 16th, 2014, 10:21 AM
From the workshop manual (which you should probably download).
System pressure, engine warm at 2000 rpm .............
2,5 - 4,57 kgf cm2 (35 - 65 Ibf in2)
Old May 16th, 2014, 10:59 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks, I have the manuals but was wondering more about the peak cold pressures so I am not pegging the gauge.
My SIII (~70k miles, new oil pressure pump) operates towards the higher end of the 2000rpm manual spec but only peaks at ~80psi or so (cold engine, higher revs) whereas my TR6 (~40k miles) has cruise pressure roughly the same as the Rovers but will push >100psi cold if I m not careful. Granted the SIII has the famously accurate OE electric gauge (rebuilt, new sender) and the TR6 is mechanical.....
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
sender P/N for factory oil pressure gauge 300TDi TS888 Defender Technical Discussions 4 May 28th, 2011 06:56 AM
110 Oil Pressure Gauge bjf Defender Technical Discussions 2 June 26th, 2009 12:34 AM
Oil pressure gauge mpsteil Defender Technical Discussions 3 September 14th, 2007 01:20 PM
Oil Pressure Gauge texasdefender110 Wanted 0 May 1st, 2007 04:54 PM
Oil pressure gauge/voltmeter from a D110 w/3.9L Grover Wanted 0 January 18th, 2007 01:12 PM
