2.5na oil capacity and dipstick depth - Defender Source
Old August 31st, 2014, 11:41 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
How much oil are folks using for 2.5na's and the related question; how can I tel if my dipstick tube has slipped down?
Owners manual specs 6.7 ltrs w/ filter change, w/ the 'follow the dipstick' caveat. ~6 qts on mine is 1" above the Hi notch on the dipstick, in the DANGER area.
I understand that the dipstick tubes can loosen and slip deeper into the block. Is there a height spec or detailed instructions for seating it? Didn't see any specific details in my manuals or online, but did find a few references to the tubes slipping.
thanks....
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old August 31st, 2014, 11:52 AM
Message ranewman. He has forgotten more about 2.5NA motors than most people know about them. If anybody will know, he will.
Dave
Old August 31st, 2014, 12:54 PM
Dave
Rick is New Orleans for his 10th anniversary so it may be a few days before he responds.
Old August 31st, 2014, 01:45 PM
jafir's Avatar
jafir
Jafir Elkurd
I think mine took right at 5 quarts last time.
Old August 31st, 2014, 02:22 PM
jafir's Avatar
jafir
Jafir Elkurd
After some reading and worrying, it looks like I might need to check and make sure my dipstick tube isn't too low too.
Old September 1st, 2014, 11:47 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Leaving NOLA tomoro am and back in town weds. I have a motor on the bench and can give measurements of length of then.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old September 2nd, 2014, 09:36 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks! Appreciate the help.
So, once I get a 20 or 21mm stubby or crowfoot, sounds like you just loosen the compression fitting and pull up?
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 11th, 2014, 01:19 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Check your olives
finally got to pulling the dipstick tube and the olive had moved up the tube by 1.25" per the witness marks from the original location. I measured the difference to where the olive should be and filled to there, ~2quarts. So now I am up to ~6.5 quarts which is still low per the manual, but proper per the dipsitck.
Tried to get the olive to move back down, but no luck and I d/n want to damage the tube without a replacement. Going for a new tube from Trevor. Thanks all.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 11th, 2014, 07:24 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Holy crap....I forgot all about this. If you still need the measurement, let me know. Sorry....been snowed with work since I got home.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
ac
Dipstick oil leak 300tdi aosias Defender Technical Discussions 6 April 1st, 2014 10:54 AM
Oil changes through dipstick suction Talleyrand Defender Technical Discussions 19 November 21st, 2012 07:01 AM
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
LT77 oil capacity cabell Defender Technical Discussions 4 September 29th, 2008 11:46 AM
3.9L V8 Oil capacity? JRowe Defender Technical Discussions 20 December 15th, 2003 03:44 PM
