2.5NA Diesel Fuel Economy - Defender Source
Old January 4th, 2014, 12:22 PM
spammer
Samdford Wallace
95 RRC LWB / 86 Tithnous
So the two times I have measured my fuel economy, I have been getting around 16-17mpg. That's a lot better than my RRC, so I'm not complaining. However, it is nowhere near close to the 25mpg that people boast about on this forum. The first tank was 100% highway (although I was putting the petal to the metal the whole way home) and the second tank was about 50% city 50% highway with about the same results.
Is 25mpg realistic? If it is realistic, what are the first things to check that could be bringing my fuel economy down?
Old January 4th, 2014, 12:53 PM
25 mpg is the absolute upper end, best mileage, in a stock 90, with road tires, driving 50 mph in a 90. My range was 18 to 23 mpg, with rare times above that. 16 to 17 does seem low. The biggest thing to control is your right foot. You want good mileage, slow down....
What are the details of your vehicle?
Have you verified the distance numbers with a GPS?
Is everything is proper tune? Filters changed, valve adjusted, timing adjusted and so on...
Old January 4th, 2014, 01:01 PM
spammer
Samdford Wallace
Just got the vehicle. Tithonus 110 with Michelin XZL
Not yet.
Nothing has been tuned. I'll go look at the filters today. Since this old diesel is new to me, any tips on the tune up?
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
I tested on 5-6 tanks when I first got my 110... verified numbers with GPS.
110 SW with road tires
2.5 N/A
90% Highway at 55-65 MPH (Floored)
10% City (slow)
Average 19 MPG
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 4th, 2014, 01:11 PM
Not yet.
That makes a difference. They are taller, if you have a hard top. They have very low gearing making them not that efficient on the highway. A 110 is heavier and worse than a 90.
Change the filters. Run some good diesel fuel conditioner through it. Check the timing. Normally they can do with a bit of advance.
Make sure you are calibrating distance with a GPS. The speedometers are never correct.
Old January 4th, 2014, 01:22 PM
spammer
Samdford Wallace
It sounds like maybe I am within 10% of where I should be. Probably due to miscalculation or a simple tune up.
So 25mpg is pretty much for a 110 2.5na running downhill with road tires? Perfect and ideal circumstances?
Out of curiosity, what is the real world mpg of the 200tdi? I've read 30mpg, but I'm guessing it's quite a bit lower under normal circumstances.
Old January 4th, 2014, 01:31 PM
remember the UK gallon where a lot of these figures originate is larger than a US gallon
Old January 4th, 2014, 01:39 PM
25 mpg for a civilian 90. I doubt you would get there in a 110. The 110 have the lower range transfer case and are heavier. You can change it, but then loaded, you might not have enough gearing.
25 mpg is about it for a 200TDI as well in a 90. As Jason says, be careful what you read as some people talk in imperial gallons. Anything you do, lift, larger tires, roof rack will make it worse.
Old January 4th, 2014, 01:48 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Not alot of people know that, I have even been asked if the litre is different? D'oh!
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 4th, 2014, 02:40 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I average (about 50% in town/50% freeway) about 24mpg in my 200tdi 90 on 33" mud terrains and 70mph on the freeway. I have a full width intercooler with upped fueling/boost.
Old January 4th, 2014, 06:32 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
My 2.5 NAD is getting around 19/20. That being said I don't push it too hard either. When I get there...I get there. Running the Radial Rover 32". I know it has fallen off lately due to the increasing injector pump leak.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old January 4th, 2014, 07:56 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I got 22.5 average on the trail in Utah. That's driving 20-30 mph on the dirt roads and 40-45 on the hardball. I'm a slow driver even in a fast car and I've never floored my truck. When I'm out on a long trip, I'm going for cool running and reliability above all else; good gas milage is a pleasant side effect of taking it easy. If I'm looking to haul ass some place, I'll take the LR4.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 4th, 2014, 10:33 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
The best I have been able to record was 22.8 mpg. I have only paid close attention while on long trips.
Old January 4th, 2014, 11:20 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I have achieved 25mpg highway speeds at 60ish mph in my 200tdi 110. No roof rack and running fresh 255/85 km2's.. Speedo is a VDO unit calibrated via gps and is spot on up-to 70 not sure past that. This was after a rebuild of the injectors not sure the condition of the pump seems to be original and runs well.
Ryan
84 110SW County LHD
07 L322 Vogue
Old January 5th, 2014, 12:39 AM
Korongo's Avatar
Korongo
Cameron Bell
1984 Defender 90, 1988 Defender 110
I'm getting 25ish, on the last road trip I got 28-29 highway keeping rpm's low but still running 55-60
Old January 5th, 2014, 03:09 AM
phreeb
Philip Leung
1988 Defender 90 SW - RHD Diesel
I've gotten 24 - 28 mpg on mine Sam. 24 when doing ~50% hwy @ ~60mph. I get ~28 when riding easy in town, running higher gears at low speeds. I'm also religious about keeping the tires inflated on the high side.
diesel, fuel
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
