2.5 TD fueling - Defender Source
Old October 12th, 2010, 09:18 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
2.5 TD fueling
I'm trying to get the 2.5TD running prior to removing, lift pump seems to be working but I am not getting any fuel to the injectors. Wondering if I have it hooked up right?
should the fuel line from the filter go in 1 or 2?
And what is the second fitting for?
Is 3 the bleeder?
Old October 12th, 2010, 10:14 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Power to the stop solenoid? Can you hear it click?
Old October 12th, 2010, 10:40 PM
Didn't doug and ron have it running? If so, should be hooked up correctly if it hasn't been messed with. Suspect air leak or solenoid not working for some reason.
Old October 12th, 2010, 10:51 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I think they did get it running, but the lift pump was out when I got it.
The solenoid does click
Old October 12th, 2010, 10:57 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Here is a shot from my 2.5TD before I removed it. Looks like fuel from filter goes to #2, #1 is return to tank. Can't quite see what #3 is in this photo...
Old October 13th, 2010, 10:46 AM
They are very hard to prime... You can spend hours sometimes...
Prime it until bubble free at the pump.
Crack loose all injector lines.
Once you see fuel, tighten one, then the other as it runs.
fuel
NEED 2.5 TD - NA or 200tdi JPBrown Wanted 5 January 17th, 2011 12:50 PM
2.5 TD or NA JPBrown Wanted 9 June 7th, 2010 12:00 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
300tdi diesel fueling control solenoid Chris Cox For Sale - Parts 1 January 2nd, 2005 07:22 PM
Help wanted: Difference between RR 2.5 TD and 2.5 DSE lakis Defender Technical Discussions 0 November 17th, 2004 10:23 AM
