2.5 nad fuel delivery issues - Defender Source
Old April 17th, 2016, 04:35 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
The engine has been sitting for over a year since its been started, new fuel lines and tank were installed. Mechanical pump was removed and an inline electric pump was put in. Fuel is pumping all the way to the IP but nothing out of the IP.
Any ideas what could be going on here/how to fix this?
1986 110 MOD 2.5 nad
Old April 17th, 2016, 04:44 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
have you checked the fuel solenoid is getting power and functioning correctly? It could be gummed up and blocking fuel flow out of the IP.
Old April 17th, 2016, 04:48 PM
With the new setup, you have removed the re circulation to the filter so that air can get out?
First check would be the solenoid. Take it off. If nothing looks obviously wrong, then remove the valve parts and put the solenoid back without them. If it starts, you will need to stall it to stop.
Make sure the injector lines are cracked at the injectors to let any air pump out.
Old April 17th, 2016, 08:26 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Seems like the solenoid isn't getting power.
Need to chase that down, thanks guys!
fuel
Help with 2.5 NAD Fuel System (Picture or Schematic) Bayonet16 Defender Technical Discussions 8 March 5th, 2016 10:18 AM
2.5 NAD out 200tdi in = Rocket dave_lucas Misc. Chit-Chat 23 January 13th, 2010 09:24 AM
Alternator wiring question 2.5 NAD to 200tdi dave_lucas Defender Technical Discussions 6 December 3rd, 2009 12:01 PM
2.5 NAD pump adjustments dave_lucas Defender Technical Discussions 16 September 22nd, 2009 09:40 PM
Fuel Delivery Problem JOE BAGGS Defender Technical Discussions 2 January 7th, 2005 09:44 PM
