2.5 NAD army cooling. Better with the fan out? - Defender Source
Old May 27th, 2015, 09:13 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Does yours do this?
So, trying to track down my ticking, and noticing that it happened more when warm.. i re-installed my fan and shroud. I was also worried about hitting traffic in 90 degree weather. Wanted to make sure it stayed cool for the summer.
The thing has been running right in the middle of the temp gauge with no fan at all. I put on the shroud and it runs a bit hotter. At least on the highway. When I get off the max throttle it drops down a needle width or 2. But not to the un-fanned condition.
This really blew my mind. The only way I can get the engine to fully open the thermostat (I put in a 190 or 185 trying to warm it up in winter) is to put the cooling system on it. All winter it was freezing cold with no fan or shroud and cardboard over most of the radiator.
This is the ARMY style cooling shroud. asbestos radiator shroud with connecting gaiter to the fan shroud. The fan clutch seems to be working just fine. Pretty small fan to radiator ratio.. but crazy that its better (cooled) without it... at least as long as I'm not idling for extended periods with a light tail wind.
Engine temps are confirmed with IR thermometer. The gauge is "accurate".
fan
2.5 NAD questions Uncle Douglas Defender Technical Discussions 15 November 8th, 2013 06:40 PM
2.5 nad ranewman Wanted 7 August 22nd, 2013 03:20 PM
2.5 NAD out 200tdi in = Rocket dave_lucas Misc. Chit-Chat 23 January 13th, 2010 09:24 AM
Alternator wiring question 2.5 NAD to 200tdi dave_lucas Defender Technical Discussions 6 December 3rd, 2009 12:01 PM
2.5 NAD pump adjustments dave_lucas Defender Technical Discussions 16 September 22nd, 2009 09:40 PM
