2.5 NA Oil Cooler Replacement Question - Defender Source
Old April 12th, 2015, 07:52 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I took out the radiator today b/c because it needs replacing, while I had it out I saw that the oil cooler (external from radiator) was cracked so I took that out as well and the tops of the pipes leading to it were leaking too so I want to replace those as well.
My question is if I'm getting a new radiator, can I just get one with the oil cooler built in and not have to worry about replacing the oil cooler separately? Not sure how interchangeable this would be.
-1986 2.5 naturally asthmatic diesel ex-MOD FFR-
Old April 12th, 2015, 08:28 PM
That is what I would do, if buying new. You would probably need the correct lines as well though.
Old April 12th, 2015, 09:54 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
After removing the radiator and oil cooler, I would suggest ripping out the rest of that shitty motor and swap in a 200/300tdi, om617, a GM gen IV V8 or heck, even 1/2 dozen hamsters on a wheel. Anything will pull better than that POS 2.5na.
Old April 12th, 2015, 10:24 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I plan to turn it into a boat anchor in the future but unfortunately I can't afford a tdi right now...full set up would be what, at least $4k?...not in the cards for at least a few more years but man I'd kill to put one in asap. I may explore the hamster option in the meantime, worried about how to handle their exhaust though.
Old April 13th, 2015, 03:09 PM
Greg S
Greg Sutfin
1986 90
My understanding is the oil cooler on a FFR is to aid cooling while a FFR truck sits stationary running and making power for hour after hour, day after day. If you aren't sitting stationary with the engine working hard, you don't need the oil cooler.
Most oil coolers are automatic trans coolers, not motor oil. Your motor oil gets a lot of cooling through the pan, that's why most engines don't have motor oil coolers.
The above, is my personal opinion only.
Old April 13th, 2015, 03:23 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
As I have said before.....remove the cooler, lines and the adaptor and the guts where the lines hook into the filter housing. On a "road/off road" use truck they really are not needed. GregS hit it right on the head as why these where fitted to the ex mod trucks.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old April 13th, 2015, 03:31 PM
If you are planning to go TDI eventually... Maybe buy a 200TDI radiator with the oil cooler and hook up to it. That way you are not buying two radiators. Just block off the area filled by the intercooler for now.
ac
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
Oil Cooler Line Replacement loykd Defender Technical Discussions 130 December 29th, 2008 01:37 PM
replacement oil cooler lines Tdi artm Defender Technical Discussions 3 August 14th, 2006 06:34 PM
