2.5 na diesel issues. - Page 3 - Defender Source
Old January 18th, 2015, 06:31 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You need to really have a self bleeding fuel system to be sure there is no air trapped causing the engine to miss.
The order is sedimenter, 12V fuel pump (comes on when the key is on), lift pump, fuel filter, IP, return line straight back to the tank.
Once you rule out a fuel system problem, then you can move on to injectors and other things.
Also a compression reading will tell you a lot.
RDavisinVA
Old February 24th, 2015, 01:07 AM
also did you adjust the valve clearances? did you check to make sure that the valve corresponding to the broken rocker arm adjuster isn't stuck or sticking?
diesel
Land Rover 90 Diesel ('85 + '86) + 110 Diesel ('86) johan For Sale - Vehicles 15 July 2nd, 2014 10:21 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Chris, Verizon Email Issues Resolved!!! Glenn_Guinto Support & Suggestions 1 March 5th, 2004 09:44 AM
Electrical relay issues???? PMHAH Defender Technical Discussions 1 November 20th, 2003 02:32 PM
