2.5 NA diesel - Fuel won't pump after changing fuel filter - Defender Source
Old January 10th, 2015, 07:05 PM
Ruedelesseps
Jon Atkinson
1985 110 MOD Pickup
Angry 2.5 NA diesel - Fuel won't pump after changing fuel filter
Hi,
I just followed the specs in the workshop manual to change to change the fuel filter in my 1985 2.5 NA diesel 110 (military spec), I am trying to bleed the fuel system and am unable to get fuel to pump using the manual lever on the side of the fuel pump. I have tried manually turning the engine, and filling the tank. I pulled the hose from the pump to the fuel filter off of the fuel filter to check flow and am still not getting anything. Went in for maintenance, rover was working fine when I started.
Also, in the process of trying to verify that there was fuel in the tank, I accidentally dropped a plastic cap about the size of a quarter into the fuel tank. This was pretty bone headed. I don't believe this is a cause because the fuel is was not pumping before this happened. Is this something that I need to be majorly concerned about? My work space is also not 100% level, but the tank os now about 1/3 -1/2 full which should compensate for that....?
Not having the best having the best day.
Any help you can provide would be much appreciated.
Old January 10th, 2015, 08:02 PM
Disconnect the fuel solenoid wire at the injection pump. Disconnect the line into the fuel filter and crank the engine. Do you get fuel flow? If not the lift pump is dead. If it does pump, hook it back up and open the filter bleed. Crank again until you get a good flow and then the bleed at the injection pump.
Don't bother with the hand lever. It takes forever and these are a bitch to bleed.
Old January 10th, 2015, 08:50 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Use thishttp://www.amazon.com/gp/aw/d/B00C59...110_SY165_QL70...
Old January 10th, 2015, 09:10 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
After you have done the above, take off the bonnet then remove the radiator and all hoses then the motor/transmission/transferbox mounts. Next pull that lump of shit out of your truck and sell it for scrap. Final step is to install a 200Tdi, om617 or even some hamsters on crack and power steering and off you go, loving and driving your truck like you never thought possible.
diesel, fuel
S3 Diesel 2.25, won't start after pump re-seal jgrear Series Technical Discussions 14 August 17th, 2014 05:16 PM
NAS 110 fuel light stays on after I fill it with gas. Replace the fuel pump? Neil McCauley Defender Technical Discussions 7 April 28th, 2014 08:53 PM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
Changing fuel filter question ollieskins Defender Technical Discussions 8 July 5th, 2008 11:27 AM
changing the fuel filter sflash868 Defender Technical Discussions 4 November 25th, 2006 03:48 PM
