2.5 NA Critical Spares - Defender Source
Old April 12th, 2013, 11:04 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Are there any critical spares that you would want to have for a cross-country trip in a new-to-me 110 with an unknown 2.5 NA? I understand that these motors are supposed to be rock-solid.
Old April 12th, 2013, 11:18 PM
Belts, fluids. Lots of tools.
The engines do fail. They get pushed pretty hard with highway driving.
Old April 12th, 2013, 11:36 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
A good tool box, belts , fluids , a hose repair kit , duct tape, spare lamps (tail,turn,head) and a 12v test probe. Slow and steady.
Remember before you head home to put air in your tires as this will help the drive. Good luck with the trip Chris.
Old April 13th, 2013, 12:50 AM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks, guys. Do either of you have a part numbers list for the motor, or at least a list of parts numbers for the belts?
Also looking for a workshop manual but not having much luck.
Old April 13th, 2013, 01:06 AM
Repair Manual:
Ebay Link
Old April 13th, 2013, 09:08 AM
Belts:
PS Belt Dayco 17285
Alt Belt Dayco 15405
Workshop and part manuals are here: http://www.landroverweb.com/landrove...rover-manuals/
Old April 13th, 2013, 09:21 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Jug of Rotella and some jumper cables.
Oh and a fuel filter also. Those can clog on a diesel and stop you dead in your tracks. Since that happened to me I don't travel without one.
Old April 13th, 2013, 09:28 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
An internet connection so you can log in here and ask for help if needed
I have the the following CD if you want to use it for the trip.
http://www.rimmerbros.co.uk/Item--i-LHP26DVD
Also have a bunch of manuals and stuff I downloaded over the years I could put on a flash drive for you.
Can loan you a few tools that may come in handy (remote starter switch) dependant on what you have for tools
Old April 13th, 2013, 09:35 AM
The problems I have experienced with them have been leaking injection pumps which there is no fix for otherwise just keep the rpm's down. Any idea when it was removed from service ?
Old April 13th, 2013, 09:37 AM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks, guys. That's very helpful. I have lots of tools ready to go in a Pelican case but my spares collection is still NAS Defender-specific. Dave, I'll check with you offline about the DVD, thanks.
------ Follow up post added April 13th, 2013 07:45 AM ------
My plan is to take it very easy on the drive back to Colorado. I'm a slow poke of a driver anyway, so I will plot a route on the back roads where I can drive 45-50 and nobody will care.
The truck came out of military service on Jan 30th of this year. I don't have the full service record of it's Army career yet. I would assume that the military PMCSed somewhat regularly even if it sat around, but we'll see.
Old April 14th, 2013, 02:10 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
In my driving of 2.5na diesel rovers I've had two water pumps fail and at least two fan clutches fail. Other than that they seem to keep going.
Old April 14th, 2013, 05:12 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I parked my 2.5 110 csw for almost 2 years before taking it on a long trip. Only situations were clutch master cyl. leaking (but leaking on the inside so not losing much pressure). So topped it up 2 times a day, and shifted without it once out of 1st gear. Also u-joint went bad so just packed it with grease by hand every 2 hours for the last 500 miles (though would have just taken front prop off if I really had to). So brake/clutch fluid (tiny funnel helps if its LHD) and grease gun perhaps.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old April 14th, 2013, 05:32 PM
When you buy the brake fluid bottle, leave the seal on it and poke a small hole. You can then "squirt" the fluid easily into the reservoir.
Old April 14th, 2013, 05:41 PM
jafir's Avatar
jafir
Jafir Elkurd
Thanks for this.
Old April 14th, 2013, 05:43 PM
broadstone's Avatar
broadstone
You Clever clogs!!! I like it!
Old April 14th, 2013, 06:12 PM
chris snell
Chris Snell
87 Ex-MOD 110
That's a new one to me. Awesome.
Old April 14th, 2013, 06:29 PM
It was not my idea. Someone, somewhere showed me and it is a saver especially with a LHD Defender.
Old April 14th, 2013, 06:35 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
I'd make sure your tool kit includes a 2lb lump hammer too, can be used to fix the majority of starter motor problems on a short term basis. I recently had a problem with my Tithonus were the starter motor kept spinning even when the engine was turned off. Solved with a few taps from the hammer followed later by removing and cleaning it. Id also make sure you have a 1/2 inch spanner handy in the cab, and not tucked away in a tool box in the back, that way you don't have to go looking for it if you need to remove the battery lead quickly in the case of electrical problems.
Old April 14th, 2013, 07:09 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Considering my style of housekeeping, there is no "handy" in the cab. I keep the 1/2" spanner in the battery box, where lots of extra crap doesn't accumulate.
John Karlsson
Hope Valley, RI
Old April 14th, 2013, 11:37 PM
headdamage's Avatar
headdamage
Andrew
I think that might have been me
spare
Mechanical risk of regular highway commuting in a 2.5 NA ontheway Defender Technical Discussions 18 January 29th, 2013 05:47 AM
2.5 na diesel in a 110- Advice? TCarawagon Defender Technical Discussions 6 March 20th, 2012 08:11 PM
D90 ExMOD 2.5 NA SW Stalling out trybul Defender Technical Discussions 17 February 15th, 2011 03:05 PM
Spares for 1984 2.5 NA Diesel for cross country trip dave_lucas Defender Technical Discussions 21 May 3rd, 2009 03:57 PM
300 Tdi, 2.5 NA and R380 for Sale moose For Sale - Parts 23 August 18th, 2008 01:10 AM
