2.5 N/A Diesel Running Hot - Defender Source
Old February 8th, 2016, 11:45 AM
1985 110
john
defender 110
I have a new to me 1985 Defender 110 with a transplanted 2.5 NA Diesel.
It ran with the temp gauge locked in the middle for several weeks.
Then the Temp Gauge started to go into the red - then would return to the middle for a while.
I replaced the thermostat (with one from rovers north) and - again the temp stayed in the middle of the gauge - for several weeks.
Now the temp is starting to go into the red again.
There is no sign of anti-freeze in the oil and it seems to run well.
Any thoughts? Bad thermostats? Something else?
Also how tolerant is this engine to heat?
Jeb
Old February 8th, 2016, 11:54 AM
Maybe the gauge is broken... Any signs it is really getting hot?
First thing I would check is the cooling fan viscous unit. They have a high failure rate. When you have gotten too hot, it should be locked up. Carefully try and slow it down with a rolled up newspaper. If it is working, you won't be able to slow it down.
Old February 8th, 2016, 12:02 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Get yourself a infrared temp gun and verify the gauge is accurate.
RDavisinVA
diesel
Running hot--new plugs? Davis Defender Technical Discussions 2 May 9th, 2012 08:38 PM
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
